Old 04-06-2003, 06:32 PM
tylertime tylertime is offline
d15b head swap
i was wondering if anyone knows if a d16a sohc head will fit on my d15b in my 90 dx
i know a guy selling a d16a head with hi po cam and porting and I would like to buy it
WILL IT FIT??
and i know i shouldn't be using a 1.5l but its what i got.
if anyone can help me that'd be awesome
Old 04-06-2003, 07:45 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
d16a what ?
Team Lonely Drivers
Old 04-06-2003, 08:20 PM
d16a6
from a 91 si i beleive 1.6l sohc 16v
Old 04-06-2003, 08:35 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes it will swap
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-06-2003, 08:36 PM
just a matter of bolting it on??
Old 04-06-2003, 08:37 PM
crxlvr's Avatar
not quite, no swap is really plug and play, you might have some wiring issues to play around with, do a search for "mini me" swaps and you'll get more info.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-06-2003, 08:38 PM
right on thanks a lot
Old 04-14-2003, 05:15 PM
ALL MOTOR D15B ALL MOTOR D15B is offline
it should fit im doing a similar swap..d15b1 block with d16a6 head/intake manifold...this is the setup i plan on doing..
AirMass 4-2-1 Header
B&M Fuel Pressure Regulator w/ Gauge
D15B1 Block...Decked, Honed, Bottom-End Fully Balanced, Hot Tanked
D16A6 Head Milled .035 /Intake Manifold
D16A1 Pistons w/ D15Z1 Rods (should i get these shot-peened?)
Skunk2 Cam Gear
havent decided what camshaft im going to use either a JG301 or a Dealta 260 Regrind. my compression will be about 11.1 : 1
Old 04-15-2003, 11:00 PM
Rgacke's Avatar
Rgacke Rgacke is offline
the heads were cast from the same mold so it'll fit. the D15 isn't so bad as long as your using a good tranny.
"shut the door Joshua, and let death pass by..."
K&W block sealer after failed head swap Bob9646 Thunderbird 4 07-19-2009 09:33 PM
head swap for lt1? kennynobodyrs Engine and Transmission 1 04-29-2009 07:36 AM
92 d15b with 91 d16 si head swap -Help. bsyeth '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 09-04-2006 12:20 AM
