Old 04-26-2005, 07:02 PM
crxman321 crxman321 is offline
question about D15b vtec swap
I have a 89 crx dx can i use a 90 si Tranny with a stage 2 clutch for an 90-91 si and 90-91 lightend flywheel? I was told that the si tranny would have to be a 89 and the clutch would have to be for a 89 also
Old 04-26-2005, 10:02 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: question about D15b vtec swap
Its all dependant on the tranny... So if u use an 89 tranny, u have to use an 89 clutch... It has less splines on them than the 88 and up... But since u want to use a 90 tranny, then yes, u can use a 90+ clutch and flywheel... And either will bolt onto a D15B VTEC since they are D series trannies... And an Si is definately reccomended for the gear ratio...
Old 04-27-2005, 04:55 PM
Scott82 Scott82 is offline
Also get the clutch kit for the flywheel, is you use the 92-95 flywheel then use that clutch kit just get a cable tranny throwout bearing. If you use the 90 flywheel then get that clutch kit. One is a recessed flywheel and the other one isn't
