Old 10-24-2003, 01:14 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
shifting w/out using clutch
what does it mean when you can shift gears without using the clutch?
cause my car does it in every gear.
Old 10-24-2003, 01:38 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: shifting w/out using clutch
Your car does it in every gear? You must have an automatic then.
j/k if you are seriously saying you can shift without pressing down the clutch in means your clutch is so worn out than its going to die any second now.
Old 10-24-2003, 01:39 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
everyone should be able to shift without using the clutch, but its not good for the tranny
KoRnSaQ
Old 10-25-2003, 01:55 AM
BullShifter's Avatar
Any manual transmission with synchros can be shifted without using the clutch. If done correctly its fine for the transmission's & actually less wear on the clutch.
Now if your cruising @ 50mph in 4th & nail it, then your car sounds like its going fast, but actually hardly moving - that means your clutch is worn & slipping.
Auto trans would not be possible without clutches.
Old 10-25-2003, 12:15 PM
gsf1200m gsf1200m is offline
I can upshift and downshift all the gears fine. Sometimes I get a bad grinding sound but if I do it right it goes in very fast and smoothly.
Old 10-25-2003, 03:37 PM
Just don't do it into 1st gear, not even with the clutch unless hardly moving. Thats exactly how it should go fast(not too fast) & smooth with very little pressure. You should not feel any resistance or a nice little grind will occur.
If you want to get real serious about it, you could have every other tooth ground off on each gear. The only problem with that is it may pop out gear when not on the gas, so you have to hold it in gear.
Old 10-26-2003, 01:37 AM
got v-tec?'s Avatar
Re: Re: shifting w/out using clutch
ARE YOU SURE? CAUSE ITS MY BACK UP CAR AND IT JUST GOT A NEW CLUTCH REPLACED CAUSE TYHE OLD ONE WENT OUT, ITS NOT SLIPPING AT ALL AND GO'S INTO EVERY GEAR VERY EASILY, AS EASY AS PUSHING IN THE CLUTCH AND SHIFTING. ITS CRAZY
Old 10-26-2003, 03:04 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Re: Re: shifting w/out using clutch
ok... now look at every other post beside that one... your clutch is fine...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 12-03-2003, 05:49 PM
R.A.T.M. R.A.T.M. is offline
I want a clutch like that...
Old 12-03-2003, 09:08 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
ive done it on both hondas i own, from experience its best to be at a certain or be above a certain rpm and as your pulling it to the next gear it will go right it and as for downshifting take it out of gear rev up and then downshift and it should go in without any grinding
2002 Acura TL Type S
1991 Honda Crx Si
1995 Town Car Shuddering after 1 year without use olopezm Town Car 16 09-14-2010 05:37 PM
92 Accord hard to shift in and out of park rango25 Accord/TSX/Accord Hybrid 5 11-12-2009 04:57 PM
Can't shift out of park mtammons MDX | Pilot 1 08-06-2009 02:50 PM
Transmission not shifting smoothly after using cruise control dizzle1 Intrigue 0 03-08-2009 04:46 PM
shifting w/o using the clutch... civic_boy91 '88 - '91 Civic | CRX | Wagon | Shuttlee 19 03-12-2006 01:53 AM
