Old 03-07-2006, 08:32 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
shifting w/o using the clutch...
anyone ever try this?...well today on the way home from work i tryed it out (i was going to stop if it went bad..lol). i was shocked to find that driving normal (not using the chutch) it didnt grind at all, if you rev match its all good. im thinking it cant be too good, but i really dont care..lol i have 3 dx trannys 2 were free and 1 is blown(due to my sister trying to drive my car...) and 1 si tranny i dont know if i want to put in... so im not too worried about blowing it...
i just wanted to know if anyone has done this before (im sure ppl have) and if it can be done racing(maybe make shifts 1/10 sec faster?)
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-07-2006, 08:37 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: shifting w/o using the clutch...
It only works if you rev match...well works correctly. I wouldn't really recommend it for racing, just stick to using the clutch instead of messing around trying to rev match it....unless you have really good control and can do it continuously.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-07-2006, 08:46 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
I had to limp a car home one day using this method, but I wouldn't recommend it for everyday driving.
Old 03-07-2006, 11:03 PM
duffman868 duffman868 is offline
i do it all the time when i am lazy or driving with my knee. but if done while racing you will most likely grind the gears
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 03-07-2006, 11:17 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
wouldn't be good for racing. When shifting up gears you have to wait for the RPMs to drop down to the right area so you can pull it into gear. Waiting for the RPMs to fall is a lot slower than using the clutch. And if you just jam it into gear without waiting for the RPMs to fall, then you're risking some wear and tear on your tranny.
Driving my truck the only time I use my clutch is starting out in first.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 03-08-2006, 06:54 AM
Hybrid1990crx's Avatar
Basically what you are doing by shifting without the clutch is working the synchos overtime after a long night of drinking. Basically all a syncro does is match the speed of your drive gears (by either speeding up or slowing down the gears depending on a upshift or downshift) to the speed of the gears on the counter shaft to get a smooth shift. The synchro does this by having a clutch like material on it and its tapered, and the gear is also tapered, so the cone of the gear fits inside the syncro to match the speeds.
heres a pic of a syncro real quick
you can see the rough material on the inside.
What you see on the outside is know as the teeth, or DOG teeth. This is what grinds when a tranny doesnt go into gear.
So anyway I kinda got off track. By shifting without the clutch you are putting excessive pressure on the synchros which will cause them to wear out prematurely. So basically its bad.
Old 03-08-2006, 07:38 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I've done it a few times. Rev match to find sweetspot and slips right into gear.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-08-2006, 05:32 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
As a former professional truck driver, I'm very familiar with shifting without the clutch. It's called 'floating' in trucker-speak.
I bought my 90 Civic LX with 75,000 miles. I figured I'd save some wear and tear by rev-matching, shifting without the clutch. At 175,000 miles, my transmission was toast. One of the bearings was bad. I had never raced the car.
You're not saving any wear and tear by shifting without the clutch. The only benefit is if you're lazy or tired, and just don't feel like using your left leg. If that's your condition, just get an automatic.
4DF
Old 03-08-2006, 07:35 PM
SiZ's Avatar
SiZ SiZ is offline
It would be retarded while racing, you'd have to wait too long to shift.
Old 03-08-2006, 09:26 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Ive tried this...I cant even get the damn car into gear...at all.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-09-2006, 03:12 PM
pokey69 pokey69 is offline
Done it a few times, kinda cool for cruising around. But, Not fast by any means.
Old 03-10-2006, 06:34 AM
I agree. Thats when WOT shifts come into play
Old 03-10-2006, 01:14 PM
FrodoGT's Avatar
Never tried one of those....prolly scare the hell outta me.... But Id be near the rev limiter already...Ive missed 3rd at about 7500rpm, and that sucked ass. Still dont think I got it much past 8 though.
Current project:
Rio Red 91 hatch.
Old 03-10-2006, 01:22 PM
ATMDC's Avatar
ATMDC ATMDC is offline
my tranny is about dead, i wana try this, can someone explain how to do it, or send me a link that shows how, i dont understand the rev-matching thing?
Old 03-10-2006, 02:09 PM
i just rev to about 3k lift foot off gas and shift. i think it is more of a practice thing then someone telling you how to
