Old 10-30-2009, 04:42 PM
rango25 rango25 is offline
Question 92 Accord hard to shift in and out of park
I have to push very hard to get my 92 Accord automatic trans shifter into park. also very hard to get it back out of park. Dose it neet a cable adjustment or what?
Old 11-11-2009, 09:51 PM
somick's Avatar
somick somick is offline
Re: 92 Accord hard to shift in and out of park
I would say: "Yes"
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-11-2009, 10:37 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
I don't think it's the cable. Probably, the park mechanism (inside the transaxle) is stucked inside. It's very hard to repair. Or maybe the shift interlock doesn't open completely.
There's a way to check: Remove the TRS (transmission range sensor) from its shaft, and see if force still remain in the shifter. If so, then it's the shift interlock solenoid.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-12-2009, 03:38 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
A lotta floor shift automatics get real hard to move the shifter simply from something sticky going down the slot around the shifter too. I've seen some you needed two hands to move the shifter, simply because someone dumped a few sodas or coffee on them...that stuff dries up HARD over time. If there's any sticky residue around that slider that moves with the shifter (the part that covers the slot the shifter moves in), that may be your issue. A simple warm water and soap clean up will take care of it. Be sire the run it all the way down to L1 and clean the whole thing...
Also make sure the shift detent button is moving freely.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-12-2009, 03:41 PM
I was just thinking...there's that slot on the shifter that you put the key in to bypass the shift interlock solenoid....wouldn't doing that and trying it tell you if it was the interlock causing the problem?
...empty gun rack.
Old 11-12-2009, 04:57 PM
If he doesn't put the key in, he'll not be able to move the shifter from/to park at all.
He's able, but it's hard. It's why I said maybe it doesn't open completely, but it opens.
Tags
1992 , accord , automatic , gear , shift
