Old 10-23-2003, 03:04 PM
guttedsilvercrx guttedsilvercrx is offline
Angry keep blowin fuses
hey i just finished COMPLETLY gutting my 89 crx and now i keep blowing fuse #8 which is tail lights, instrument cluster. its a 10amp fuse and i tried putting a 25 just to see if something would start smoking but the fuse never blew but nothing worked either. i guess i have a short somewhere. please help me out cuz im getting my camber kit on saturday so i can get the car back out on the road. thanks
Old 10-23-2003, 03:32 PM
crx_insanity crx_insanity is offline
Send a message via MSN to crx_insanity
well i just had the exact same problem and it was my stereo the dimmer wire was grounding out so i suggest that you check that or do u even have a stereo in your car well either way it is a red and black wire that was shorting out on my car and blowing the #8 fuse just fixed it a couple of days ago well hope this solves your problem tell us if it fixes it
The Only Replacment For Displacment Is Technology
Old 10-23-2003, 08:17 PM
yea i took my radio and everything else out in the car the only thing ihave left is my guages that are just hanging there for the moment until i get the time to make a metal dash. i looked at all of the wires and i didnt see any that were disconnected or cut so i dunno. ill try what you said.
Old 10-24-2003, 06:51 PM
daddys's Avatar
daddys daddys is offline
when i bought my car my brake lights didnt work and when i put a fuse in it would blow as soon as i tapped the brakes,,,turns out that the brake lights and the horn share the same fuse and the horn was disconnected and touching the frame of the car,,,,maybe you should check your horn,its located under the driver side fender and bumper ,but im not sure about the instrument panel light,,mine worked when my brakes didnt
Old 10-24-2003, 09:45 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: keep blowin fuses
I'm getting the same thing. However, I think that my problem is the dimmer box in the dash. That is what I am going to try first. I have to figure this out too, so if you come up with anything, I would like to know too! Also, daddys, the brake lights are separate from the dash/marker lights, so that fuse would have nothing to do with it...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-03-2003, 09:00 AM
hey the other day i was checked all of the wires with an ohm meter "i think thats what its called" my pops told me to try to use it to see if the wires had a break in them somwhere. well i pulled the intire guage/radio harness out to check all of the wires and the all were fine and when i plugged it back in i put a new fuse back in and everything worked fine, except my guage lights still dont work but my tail lights work fine now. im just going to leave it cuz everytime i get around to tryin to find out whats wrong i end up f-in something else up so the guage lights dont bother me plus im ordering all new autometer guages in about a month to get ride of my guage cluster so i can make a metal dash.
Old 11-03-2003, 09:52 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
I had a loose connection in my dash wiring plug that went into my gauge cluster...that caused my lights to work intermitently. After I cleaned up the connections (spray a little of that TV connector spray on it too) that seemed to help.
Glad you got your lights to work....it was probably just a short somewhere...
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 11-03-2003, 04:55 PM
thanks sastanley ill try sprayin some cleaner on the plugs to see if htat works, thanks man
Old 11-05-2003, 10:53 PM
balln69 balln69 is offline
Send a message via AIM to balln69
I had the same problem with my supra, i put a new head unit in and had sum xtra wires so i put em off to the side, and my power mirrors n other shit stopped working, if you dont have a stereo in, then jus get sum electrical tape n tape the ends ... well thats my
91 Crx Dx
{[Pensacola]} Crx Representing [{P'Cola}]
({[-Later]})
Drop a Gear
and Dissapear
PLZ help 94 grand am ignition fuse keeps blowin! thewizard67 Grand AM 7 05-03-2014 07:46 AM
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
Amp Fuse Keeps Blowin deucejr15 Car Audio 19 09-02-2006 06:58 PM
Fuse keeps blowin mpritch Aurora 1 04-19-2004 11:30 AM
Dash lights keep blowing fuses crx_insanity '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-22-2003 05:31 PM
