Old 08-30-2006, 05:30 PM
deucejr15 deucejr15 is offline
Exclamation Amp Fuse Keeps Blowin
I have a 1600 watt 4 ch. amp hooked up to only 2 12" subs. everything is hooked up properly and when turned on the amp and subs work. but after 2 minutes or so the 30A fuse on the amp itself blew. Does anyone know what I need to do to fix this??
Old 08-30-2006, 08:59 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Amp Fuse Keeps Blowin
a 30 amp fuse on a 1600 watt amp ? If you are bridging your amp channels, you might need to up the fuse size, the manual should give you some better answers.
Old 08-30-2006, 11:01 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
What brand amp. i dont know anyone who crams that much power through even4 30amp fuses.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-30-2006, 11:46 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I run about 450 watts , 2 ohm, bridged on a 20 amp then into a 20 amp CB..
IIRC, a Memphis Audio 1000 runs a 50..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-31-2006, 05:40 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Like pimprolla said what brand and model amp is it and one of us on here will either already know the specs for it or be able to find the specs for fuses for it. Oh and btw welcome to automotive forums.
Old 08-31-2006, 07:10 PM
Yes welcome to the sight.
I always thought the general idea was 50watts rms=1amp. Im not 100% sure on this but i think im close.
Im thinking he either has it wired to the wrong impendance, or the 30 amp fuse isnt what belongs there. Im also thinking if thats the fuse that came in the amp fom factory it might be a cheaper brand amp like legacy, lanzar, pyle or pyramid. But i can only guess at this point.
Cardomain
Old 08-31-2006, 08:57 PM
it is a brand new pyle pla-4240. it came with a built-in 30A fuse. Also, if i should increase the fuse, how much?
Old 08-31-2006, 11:01 PM
Somethings wrong if it's blowing it original-rated fuse..You may want to make sure you aren't running a 2 ohm speaker on a 4 ohm stable amp, or anything else that could draw too much power...
Old 09-01-2006, 12:56 AM
Now what subs are hooked up and what wiring configuration. Also i cant find any rms ratings on that amp but by how they are usually done its probably closer to 150-200rms a channel and thats full power. But for $100 you cant complain.
If the wiring is right then go up in intervalls of 5amps not to exceed 40amps total cause that can cause some damage if it gets to hot.
Cardomain
Old 09-01-2006, 10:38 AM
Either that amp is pretty old or you wrote down the wrong model number but I can't find a pyle pla-4240 model amp information anywhere. Check the model number again and let us know
Old 09-01-2006, 01:46 PM
the subs are Dual xnbp12d 12" in a bandpass enclosure. impedance on the subs is 4-6 ohms. I have a 2-channel Dual 460 watt amp which works perfect, but when I switched the amps everything was hooked up properly, but then the fuse blew. The pyle is a 4-channel and the subs are the only thing running off of it right now(until i get some 6x9's). They are bridged.
This is the amp.
http://shopper.cnet.com/PYLE_Blue_Wa...-31954560.html
http://cardiscountstereos.com/catalo...ct+%23=PLA4240
Old 09-01-2006, 02:38 PM
Audio Guy
how have you go that 4 ch amp connected ? I don't think you can connect all 4 channels to the same speaker.
Old 09-01-2006, 06:26 PM
I had no problem with google.
Bridged it should be fine. Unless it has a short somewhere or the subs are blown and they take some time to short.
Just did a search on the subs, i hate how cheap brands rate there stuff 400-600rms WTF. I can understand recomended. But rms is not recomended power.
Are they in the original bandpass im trying to figure out how you bridged each sub if there is one connection. But they are the right impendance.
Cardomain
Old 09-01-2006, 09:20 PM
It's bridged, so it isn't on all of the channels.
Old 09-01-2006, 09:28 PM
they are in the original bandpass. does anyone know what i can do to fix this?? please help, thanks!!
