Old 10-23-2003, 12:42 PM
Bell78 Bell78 is offline
Angry 1994 Grand AM 3.1L issues!! HELP!!!
I'm new to the boards but have noticed so far, you all been very knowledgable throughout!!
I have two seperate problems..just need advice or to know where to start.
I have a 1994 Grand AM SE 3.1L V6. it's been a decent car. its got 178,900km on it.
1.)I had just had my yearly set of rotors put on it...as well as had the back brakes done a little while ago. Everything should be fine. but it is not.
my mechanic, who is my close friend's father and owns a shop, did the work, as he always does. I've noticed the brakes are obviously much better with minimal pulsating at high speed 'quick stops.' (there's still a bit of a shudder, but whatever) Now, all i am dealing with is an annoying 'tick tick tick' sound emitting from my drivers side wheel. like something is hitting something else. He haspulled my wheel several times and has looked at everything..anti rattle clips, the pads... has taken it for rides, and doesn't getthe tick tick..(but he also has somewhat poor hearing) so i went with hm. Do ya think the wheel ticked??? nope! anyways, i know the noise is there, as i've been commuting lately and when i'm in traffic and in the left lane against the barrier, i can here the noise quite clearly..."click click clickclick.." He has informed that ya, i could use a Driver side wheel bearing soon..he did my passenger one las summer...and they can hear 'the early warning noises" of that going, but where the hell is this click coming from. he's had my car, ive gone wioth him, and it doesnt seem to decide to do it when he has it...so rather than bug him again...(and he's hard to get a hold of) .... any suggestions? backing plates? anything related to the calipers??? i only have limited knowlege of cars, but it usually happens after i've drove for awhile and especially after the car is driven for an extended period...it's driving me nuts..that and i need damn rotorspads all the time....(Grand Ams in general more frequently than other cars i've noticed!!)
2.) my second quesiton...another one i haven't got him to look into too deeply other than the mention of possibly having a windsheild leak somewhere..is that I have a soaked floor. all the time. but especially after heavy rain. The driver's side is the worst, followed by a damp to wet passenger side front and the worst is the passenger back. There is an inch or more of water back there after heavy rain or driving in it. I removed the Wiper Well cover and cleaned as much crap outta there as i could. it wans't all that horrible though(that and i couldnt get my wiper arms off>). I have no clue where this is coming from. the carpet by the firewall appear dry. i's jsut where the surface is flat is the wettest. and the back pass. side. my driver pass. side is DRY!! what the hell could be causing this and where the hell is this water getting in considering the firewall carpet is dry? i sprayed it down one day(although was pressed for time) near the front windsheild and the back pass. dor, and didnt see anything, but i need another person to actually sit in the car while i do it...any leads/suggestions??? I know theres two weird vents or 'humps' under each seat. don't know what they are?? wher do they go?? could the water be gettin in that way??
Old 10-24-2003, 05:58 PM
mikegee mikegee is offline
Send a message via AIM to mikegee
my work truck is an 85 gmc s15 and i had the same tick tick tick but i mostly got it when turning. and the tick tick tick came from something with the horn its been a while so i dont remember. i let the problem continue with out care and it killed the battery often. ummmm dont know if i helped any but tell ya mechanic to check the horn.
Old 10-24-2003, 06:02 PM
as for the water im sorry but all i could do was laugh. reason: i had a 90 corsica and i think i even had the same engine as yours i took the car all the way to 182,000 miles. but my point is i also had the same leaking problem. all i can say is good luck. i had the car for bout 40,000 miles and the entire time i had the water problem and never found the cause.
Old 11-04-2003, 07:50 PM
jimfather jimfather is offline
1994 Grand Am GT holding water inside!
I have the same problem with my vehicle. Most recently, I had the windshield replaced. But with the very little rain we have had in my area, the problem did not show up until a heavy rainfall. Prior to the windshield replacement, NO-PROBLEMS! Your guess is as good as mine. I had just vacuumed out the water today, and it is supposed to rain tomarrow, and you know what is next. Let me know if you find a solution, PLEASE!!!
Old 11-04-2003, 08:42 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: 1994 Grand Am GT holding water inside!
Your waterleak problem is easy to figure out!!! Before windshield no problem after windshield problem. Guess where I would look?
To help find a water leak get your garden hose take the nozzle off turn the water on low and place the hose on the car looking for leaks inside.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-05-2003, 06:11 AM
bmtphoenix bmtphoenix is offline
I'd take it to a body shop to find the leak. Or a collision repair place. They're more used to that type stuff than a normal mechanic.
As far as the ticking goes, do you have wheel covers? If so, take them off and see if the noise goes away. Wierd, I know, but it wouldn't be the first time that's happened.
Old 05-16-2004, 05:44 PM
Chubes Chubes is offline
Re: 1994 Grand AM 3.1L issues!! HELP!!!
I've had the leaking problem on a couple of vehicles and it has been the windshield seal both times. I'd take it to a glass shop. As for the ticking sound, if the rotors had just been replaced I'd check if the squeel indicators are still in the right position and not hitting the rotor somewhere. Sorry about digging up an old post, but I ran a search and figured I'd kick in my 2c.
Old 05-29-2004, 04:38 PM
helpme0768 helpme0768 is offline
I have a 1994 grand am and I to have a leaking problem floorboard on pasanger side after rain soaked.I figure it was the windows or windshild
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
1994 olds 3.1L hesitates at 60mph micropone Cutlass Series 3 10-22-2008 08:48 AM
1994 Grand Am Electrical Issue - please help! chetwynd Grand AM 2 09-13-2006 05:15 PM
1994 Cutlass Supreme SL 3.1L, PLEASE HELP. GRB Cutlass Series 13 01-21-2006 07:49 PM
GrandAm 1994 se 3,1L v6 Flashers!!! genny2000 Grand AM 4 09-11-2004 09:52 PM
