Hello,
Can someone please tell me where are located the flasher connection on a Pontiac Grand Am 1994 se 3,1L v6?? We removed dash panel looked everywhere and didn't found it. We bought the replacement so we know what it's supposed to look like but we don't see it. I attach a picture so if someone please tell us where it is... It would be really, really appreciated. Thanks a lot Genny2000
I had my flashers replcaed in my car because I'm not that mechanical if you have the manual for the car go to the opposite of where it says the flashers are because thats what the mechanic told me so and use good flashers not cheapos because I have to get mine replaced again because the guy used cheap parts
Re: GrandAm 1994 se 3,1L v6 Flashers!!!
if your flasher looks more like a 5-prong relay than a traditional flasher its located under the driver side dash area, basically below the guage cluster on a white junction box called the convenience center. there are two similar relays/flashers, i believe its the outer one.....if your flasher looks more like a traditional flasher its attached to the steering column more on the right side of the column, probably all by itself..... hope this helps
talk about taking car apart to replace the flasher, yea it's under the dash, not sure where cuse there's so many relays and flasher looking things.
I have had the same problem with my 95, that black plastic cover that i see in the pic, you hvae to take it off and keep digging, it will be silver and round but its WAY up there....took me 3 hours so good luck
