Old 10-22-2003, 10:16 PM
BluFalcon's Avatar
BluFalcon BluFalcon is offline
Send a message via AIM to BluFalcon
Swapping EPROMS 1st gen DSM
I have a 92 EPROM ECU in my 90 AWD, with the appropiate wires swapped. The tach isn't reading correctly which is something that normally occurs with anything other than a 90 ECU in a 90 car, or so I'm told. I bought a 90 EPROM California ECU, recently so I could get some normal tach function back. From what I was led to believe the 90 ECU's have a smaller fuel map and are a bit less agressive when it comes to timing. I have no real idea what a California spec ECU throws into the mix, but judging from what the Smog Nazi's have done to that state, it cant be good. My question is, can I swap the EPROM from my 92 ECU into the 90 ECU? The EPROM is what contains all the engine parameters, maps and limits for the engine, correct? The ECU itself serves as a "player" for the EPROM. Has anyone done this before? Both ECU's are socketed so swapping the EPROMS isn't a big deal. I just want to know if this will work. Any info would be appreciated. Thanks.
90 Talon TSi/AWD "Project"
99 Galant GTZ "Driver"
http://www.dfwdsm.org
Old 10-23-2003, 02:14 PM
kjewer1 kjewer1 is offline
AF - Advisor
I dont think there is any difference between the regular and federal ECUs on 90s that wouldnt be covered in the EPROM. I Cant see why the fuel maps would be different, same for timing. But you can jsut add the timing back in with the CAS. I would think most of the difference is in the code written to control all the extra emissions stuff, but I could be wrong. I say go for it, but I cant say I have every tried it. 2 of my friends have 90s, but they are both on 91+ eprom ECUs. If you try it, be sure to post the results.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-23-2003, 07:32 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Yeah you could try it, I really dont know the answer. I am one of the lucky ones with an EPROM 90 ECU.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
1st gen DSM vs. the Sebring. Polygon Street Racing 11 05-06-2005 10:03 AM
WTB, 1st Gen DSM AWD Eclipse/Talon IAmCAM Cars/Parts for Sale/Exchange 0 12-07-2004 02:09 PM
Kill: GTC vs 1st Gen DSM. Polygon Street Racing 11 10-19-2004 01:48 PM
for sale: atx to mtx swap parts 1st gen blachdohcneon Neon | Plymouth Neon 0 03-08-2004 11:12 PM
MOdern EFI Swap to 1st GEN airhercules Mustang Talk 9 11-04-2003 07:59 AM
