Old 10-22-2003, 08:53 PM
Skurly_ChInChILLa Skurly_ChInChILLa is offline
Alarm install Question
First off...THIS PLACE RULES!!!!
Anyway , I ordered a security system from autoloc. I need to know where I can get a +12 volt wire I can splice into to power the sec system. Should I just run a wire straight from the battery through the firewall?? Where could I pass the wire through the firewall?
Anyone everseen the autoloc systems in action, I'm wondering if the system is a good one. Its the Svproa37, here's the lionk to the description:
http://www.autoloc.com/detail.lasso?itemid=SVPROA37
Thanx in advance.
Old 10-24-2003, 08:45 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Alarm install Question
Thanx in advance.
Oh, I see that you are planning to shove off your door handles??? Well, the door polls sound nice but never heard of them. The alarm is next to worthless though. You could have saved about 1/2 your money if you bought a real kit to do this.
Either way, the install of the doorpulls is the key. They have to be exactly right and always right or you'll always have to keep a window down to get in. Also, if this system does not have an emergency pull cable or something, you will not be able to get in your car if the battery goes dead or the remote quits unless you break a window.
Old 10-24-2003, 07:09 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
you probally should get the power from the battery. i have never heard of your alarm. i have the ultrastarters alarm model #600 and it is super sensitive.
For Sale 98 Eclipse GS, 5 spd
Old 10-24-2003, 07:47 PM
Thanx in advance.
Since I do not know your year of car. Go to www.bulldogsecurity.com
Any of the 12v+ sources in the ignition should be fine but you might want to verify the amp rating of the door pullers. Some of the cheap units pull like 40-60 amp which would warrant to go to the battery or some large wire source.
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 10:36 AM
Alarm going off when no alarm installed?? pdbarry Caravan | Voyager 5 08-30-2007 07:50 PM
'91 S10 Blazer - Alarm install questions dirgotronix S-10 1 05-17-2005 02:24 PM
Questions about Viper alarm installed in car before I bought it Jfo Car Audio 7 05-23-2004 03:42 AM
aftermarket alarm install MoReace Audio/Security 1 10-21-2003 11:39 PM
