Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-19-2003, 09:39 AM
ShinRekka's Avatar
ShinRekka ShinRekka is offline
Send a message via AIM to ShinRekka
sequencial turbo KA?
Alright I know you cant twin turbo an inline 4, and i know you gotta sequencial turbo it, but what does that mean is it just 1 turbo bolted to another turbo? or like a little turbo to spool the bigger turbo up faster? I was wondering about this because im on my way to buying a XS turbo kit and since quite a few people have turbo Ka's why not do something different, can i just bolt another turbo to the turbo thats in there? I dont think it would work but i just want to make sure before i rule it out.
Hheheheheehe my 240s gonna be so cool ordered a S13silvia front off ebay, a wangan wing, some nice rims and the jdm tails. Got a daul apexi N1 setup that i got welded to 2 1/2 inch pipe (I know 3inch pipes are better for turbo but i have this thing sitting in my garage, i did it when i had my last 240) Im gonna get it painted glossy black too. With limo tint hatch windows and tinted fronts
a police chase....that would be a rush.....
Old 10-19-2003, 11:41 AM
drifter17's Avatar
drifter17 drifter17 is offline
Send a message via AIM to drifter17 Send a message via MSN to drifter17
from my understanding a normal daily driver cannot have 1 turbo spool up another only the big rigs are equipped with that beacause of some technical problem that would arise if u had it....and something along the lines of u not making full boost until 7000+ rpm...ill find the article and post facts here...
Old 10-19-2003, 11:53 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
sequential turbos are where a small turbo is used for low RPM. say below 4000rpm then when it gets to 4000 a gate opens and lets gas into a larger secondary making it a twin turbo. ala Supra and RX-7
Twins on a 240 would be pointless although you could most likely pull the turbos from a Supra or RX-7 and then do alot of work to get them to fit / get the ECU to accept everything.
I think singles are better than twins anyway.
Old 10-20-2003, 09:08 AM
ShinRekka's Avatar
Re: sequencial turbo KA?
alright i'll stick with a single
Old 10-25-2003, 09:49 PM
DWF Engineering DWF Engineering is offline
Some cars could use a small and large turbo, Supras use two CT26s though. It uses one until X manifold pressure is reached then begins spooling the second. As boost climbs both turbos are used; the first one spooled never cuts. I think this is FAR more common than the small/large turbo design. Go for it on your car, the problems you'll have are the manifold, which both turbos attach to, the valve that allows exhaust to reach the second turbo, and controlling the two seperate turbos. Anything can be done though, what you must ask is should it be done. I think a good T04 setup would start making boost around 2000 rpm anyway. My NA KA white smokes the tires easily with a 2000+ rpm launch so would you really need the boost below that point anyway?
Parting out!!& Brand new FULLY built turbo KA S14 black mamba 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 04-30-2005 08:17 PM
Turbo ka Parts? 240droptop 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 9 02-14-2005 09:50 PM
questions regarding turbo ka kungfufoo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 11-03-2004 11:13 PM
turbo Ka vs. 5.0 TatII Street Racing 20 10-03-2004 03:30 PM
turbo KA or Sr swap Dumpy2 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 14 02-04-2004 04:35 PM
