Old 10-19-2003, 01:08 AM
Chevychris Chevychris is offline
Send a message via MSN to Chevychris
Question smoking
Hello i just bought a 91 4.3 chevy s-10 blazer 4x4. When i first start it up it smokes blueish whitish color. it seems to clear up after while. if i let it idle for a while it evenutally smokes a little. but when i stomp after it idles for a while it smokes pretty bad. i'm leaning more toward oil burning than water. I'm thinking it is either the rings or the valve guide seals. how can i tell? if my assumption is right?
Old 10-19-2003, 06:59 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: smoking
Small block GM engines (the 4.3 is the same design just missing 2 cylinders) have been known to need valve stem seals.
They will get hard and crack causing oil to run down the stems and be burned in the combustion chamber.
I would start there first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-19-2003, 10:00 AM
Re: Re: smoking
Now is this procedure pretty easy to be done? I am mechanicly inclined. Do i have to just remove vavle cover, spark plugs, rocker arms, and have a valve compression tool. and what if anything do i put in spark plug hole to keep valve from dropping into cyclinder. or do i have to remove the heads? Or what does this procedure usually cost to get done?
Old 10-19-2003, 11:39 AM
BOOZER BOOZER is offline
Re: Re: Re: smoking
Prety basic job to do in your backyard, chris.
Stop at your local chevy/gmc dealer, there has been an updated seal kit out for quite some time.As
for holding the valves shut, use an air compressor &
the appropriate fitting in the S/P hole. No compressor than rent one,the small ones are cheap.
Labor, lets see ??? at about $85.00 an hour your looking at about $340.00 plus parts.
1999 expedition is smoking grey smoke bacan333 Expedition 2 12-13-2008 01:37 PM
smoke, smoke, and more smoke 97GSTspyder Off-Topic 13 08-23-2005 02:07 PM
Smoked and smoked bad by an Evo 2000LS1Z28 Street Racing 23 08-15-2005 03:08 PM
Smoked by a Lightning, Lightning smoked by curb... CassiesMan Street Racing 28 01-11-2005 02:16 AM
smoke or be smoked b16b bomber Street Racing 32 12-31-2001 10:48 PM
