Old 08-21-2005, 06:01 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
smoke, smoke, and more smoke
I've searched thouroughly and i think i've come to the conclusion that i either have a shot head gasket, bad turbo, or valve stem seals. My car blows a lot of white smoke, especially at boost/right after boosting. Took my radiator cap off, coolant looks a bit cloudy and there is a bunch of oil on the bottom of the cap. That leads me to believe head gasket. The car smokes a lot more at boost, which i think could be the turbo also. Valve stem seals are old as shit and probably need replaced. The smoke smells like burnt radiator fluid. Sometimes it smells like i'm burning oil. Damnit! I JUST put in a new tranny/clutch. Not even a week and a new problem arrises! Why me!? Looks like i'll be in the garage for quite some time, yet again. This will be my first time ripping the head off. No worrys, i know what to do I'm going to replace the timing belt, balance shaft belt (maybe even eliminate those suckers), new tensioner, new water pump, and anything else that might need replacing and clean up that side of the motor (any oil/grime on the block, etc). Soooo. Before i actually start ripping the head off, anyone want to give any input? Any useful tips, or other ideas of what could be causing my car to smoke?
Thanks.
Steve
Old 08-21-2005, 06:58 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Re: smoke, smoke, and more smoke
Yeah its either turbo, head gasket, or valve stem seals. Its not to fun replacing the water pump and all the other stuff. What kind of turbo are you running on ?, your stock one ? And how many miles on the turbo ? Maybe its time for a 20G .
Old 08-21-2005, 07:14 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
when you discover the problem, let me know. Because unfortunitly thats exactly what started happening 2 nights ago after 7-8 runs at the local track. I don't have any smoke coming out at idle, or under boost. It only puffs a small amount of white smoke out durring shifts, and POORS out like a smoke bomb after 3rd gear pull to 7k! I had somone run my car on the track while i watched in the passenger seat in another car. At the end of the track when he let off the gas to slow down it was increadable. It looked like my tire was on fire, it was coming out from underneath my muffler, through my wheels, and out the tail pipe.
So i feel your pain. I personaly think its my turbo. But I dont have the time to figure it out this week. So, Please, with sugar on top. Keep me informed!
Thanks
Scott
DSM geek
Old 08-22-2005, 12:01 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: smoke, smoke, and more smoke
The guy has major issues with the way his car is running, and your telling him to buy a huge turbo.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-22-2005, 12:13 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Re: Re: smoke, smoke, and more smoke
Eh...If its his turbo, then he needs another one. It's a valid excuse in my book to upgrade.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 08-22-2005, 12:19 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
My turbo is starting to smoke but. It really only happens when i shift gears though. i have a stock one with 156k on it. Im surpirsed that it still runs after all of that
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 08-22-2005, 12:32 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Have you done a compression test? If it's a bad head gasket or vave stem seals it should have low compression. Sounds similar to what happened to my talon (still not sure cause i haven't taken it apart yet) it was smoking a lot after it overheated so i did a compression test and got 120-90-80-110, i cried myself to sleep that night.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-22-2005, 12:57 PM
the last time i did that was in febuary when i got the valve job i think that im good there. It's just time to upgrade turbos
MODS
Old 08-22-2005, 02:47 PM
i did a compression test about a month or so ago and i got 145 (or 155, can't remember exactly) on all 4. i just took the turbo off last night. there is a good amount of shaft play and there was a bunch of oil in the inlet and on the wheel...think i found my problem
Old 08-22-2005, 03:07 PM
ok i was thinking about doing a rebuild....found this kit on ebay. http://cgi.ebay.com/ebaymotors/HUGE-...spagenameZWDVW
not a bad price. now, i don't trust myself to rebuild any turbo. what kind of shops rebuild and balance these things?
Old 08-22-2005, 03:12 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Check out how much you can get an EVOIII for here- http://koumotorsports.com/new_products.html
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-22-2005, 07:51 PM
ez1286's Avatar
I tried rebuilding my turbo once and it didn't work out. You might be able to find a used turbo for about that price. You should take the turbo apart and check the shaft i think mine was messed up.
Old 08-23-2005, 06:50 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If you do your own rebuild, don't you have to send it out to have it spin balanced?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-23-2005, 01:07 PM
I thought that one of the tubes that connects to the intake put oil compresser housing. I have had oil in there for a long time. I also have oil in the upper ic pipe, damn i need to change this turbo.
MODS
