Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 10-17-2003, 10:51 AM
ygle18001 ygle18001 is offline
P0400 EGR mulfunction
My check engine yellow light on and local garage diagnose with P0400 which translate into EGR malfunction. I took the car to local part store and borrow the meter to clear the code. The code clear and light was off and never come back for about one week.
The garage quote me about $1000 for the job which replace the valve, two sensors. Is the price in the ballpark ? Labor is about $200. Parts are about $800.
Question:
Is the problem hiding somewhere and onboard computer can not detect ?
or it this just one time hiccup ?
Thanks for your help.
Old 12-28-2003, 10:41 PM
eltigre eltigre is offline
Re: P0400 EGR mulfunction
Question:
Do yourself a favor and check the BPT hose....it comes off the EGR valve up into a piece just above the engine toward the back.....usually those deteriorate because of heat and lead to an intermttent check engine light...small rubber vacuum hose...few bucks
Old 11-25-2004, 08:28 AM
mustangfreek mustangfreek is offline
Talking Re: Re: P0400 EGR mulfunction
I may have the same problem being the EGR valve's BPT hose...the Oxygen sensor and PVC valve was replaced 6 months ago...but it has some up again just yesterday. How do I find the EGR valve? It's kinda crowded in there. Not like my old 68 mustang were I can actually crawl into under the hood.
Old 11-27-2004, 08:59 PM
Re: Re: Re: P0400 EGR mulfunction
Driver side of engine above and BEHIND to the driver's side where the Throttle body is
Old 01-03-2005, 03:35 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
most of the time they just need cleaned out. carbon deposites break free from the intake manifold and get caught in the egr valve and sometimes lodges in the spring keeping the valve open. just take it off and clean it. if problem keeps coming back eigther get hotter spark plugs or remove intake and clean it. it really is a do it yourself job. if the gasket get torn on removal purchase a new one or use gasket making silicone.
96 Intrepid EGR valve meltdown ccundy Intrepid 3 07-28-2010 06:23 PM
2000 Accord EGR and decarbonizing sugarb Accord/TSX/Accord Hybrid 0 06-08-2010 08:53 PM
EGR elim. on 93 1.9L braunie4 Escort 4 06-05-2010 03:47 PM
95 Intrepid EGR Valve apmavis Intrepid 0 07-23-2009 05:20 PM
