Old 10-17-2003, 06:51 AM
jinxe#14 jinxe#14 is offline
Angry Losing Boost!
Alright, I've got a problem with my baby, she runs fine until, I floor it, what happens is ill put it in first, then i floor it, boost goes to about 15 like its supposed to, and then wham around 4000rpms, she cuts out, boost goes to 0 and it wont let me accelerate unless i shift gears.
I've already given her the full tune up, and im still lost, any ideas and help would be great!
The only mods im running are a full three inch exhaust from the header back, and a three in. intake and an apexi bov. and magnecore wires with new ngk plugs.
Old 10-17-2003, 08:51 AM
turboawdgsx turboawdgsx is offline
How much did you gap the plugs to? It should be around .28-.30. Also is your BOV recirculated back into the intake?
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 10-17-2003, 09:16 AM
the plugs are gapped at .030, and im not sure about the bov recirculating, but at check here on my lunch brake. but im pretty sure it is.
Old 10-17-2003, 10:23 AM
kjewer1 kjewer1 is offline
AF - Advisor
I doubt the BOV is dumped back in. At any rate, it should cause this. I ran vented for years (not that it doesnt suck). Is this a 1g or 2g? If its 1g my guess is a boost leak is putting airflow over the fuel cut threshold. A 2g shouldnt hit fuel cut on a stock turbo, even with a leak. So my next guess would ignition as well. Does the car just basically shut down, or will it sputter and limp along if you stay in that gear, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-17-2003, 11:32 AM
SpyderEclipseGst SpyderEclipseGst is offline
Re: Losing Boost!
Is it a 1st gen or 2nd? Other than wires/spark plugs. Sounds like a fuel pump problem. I ran 16 psi on stock fuel pump fine. But Every car is diffrent. Otherwise I havent a clue.
GT35R Tuned GSX Spyder.
Old 10-17-2003, 11:37 AM
AF - Advisor
I ran 12s on the stock pump for some time. The only pump related thing I can think of is when the person installing it forgets to add the spacer and/or Oring. Then it will give the exact symptoms described above. It usually happens right after (or shortly after) installing a pump though, it doesnt just happen randomly to a stock pump. Good idea though.
Kevin Jewer
Old 10-17-2003, 12:43 PM
Im sorry, im running a 2nd gen, and im also running a walboro 255lph pump. The only other thing that it's doing is if im just sitting and i rev my car, even without being in gear, the rpms will drop really low to like 200 or 300 then rise back up to about 800/900.
Old 10-17-2003, 03:51 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Losing Boost!
you are hitting your boost cut, so either dump the BOV or get a boost controller. i just went thru a similar problem, where everything shuts off at about 4k rpm and idling is erratic and sometimes the engine would die alltogether on shifts, the rpm just dropps to zero.
Old 10-17-2003, 11:14 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Are you running a AFPR with that 255? Is it a HO 255? That may be the cause of your idle problem
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
super charger losing power kellyledet Grand Prix 2 01-19-2011 11:25 AM
2000 Pontiac Sunfire GT Randomly Loses Power Karan Cavalier Problem Diagnosis 19 04-30-2009 06:36 PM
Losing boost 02GTPman Grand Prix 3 05-17-2007 04:24 PM
losing boost dannydee42 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 10-07-2005 11:32 PM
loseing boost need help 92VR4Red 3000GT/Stealth 10 10-15-2004 03:25 PM
