Old 05-16-2007, 11:05 PM
02GTPman 02GTPman is offline
Losing boost
Hey i have a 3.325 pulley on my super charger and i normally boost around 11 psi but for some reason i cant get it past 7 any ideas on why that is?
Old 05-17-2007, 10:46 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Lossing boost
Does it appear to be just the boost indication low or are you having any driveability problems? Does power feel up to snuff? Also, any mods like a re-programmed PCM module (DHP, Intense or ZZP)? How is the SC drive belt?
It is not uncommon to get an erroneous boost indication with a smaller SC pulley. Alot of GTP owners do not rely on the DIC boost indicator after supercharger mods. You are better off with an aftermarket boost gauge which gets it's vacuum signal off the MAP sensor line and is more accurate.
Timeslip 08/12/06
AF Community Guidelines
Old 05-17-2007, 02:44 PM
Re: Lossing boost
im not pushing as much power as normaly cause i got beat last night by someone i normally beat it feels like i am losing power after first gear my sc belt seems fine no missing teeth that i could see friend said it kinda sounds like it is slipping... and that some of the pullies feel a lil loose to him
Old 05-17-2007, 04:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Lossing boost
The smaller pulley may be causing the belt to slip. I'd try a new one (Goodyear Gatorback is recommended) or your supercharger belt tensioner may be weak causing belt slippage.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
