Old 10-15-2003, 11:48 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
LS-Vtech
i was wondering, i was thinking of doin the ls vtech, b18a1block with b16head. i was wondering what head work has to be done to make this work.
KoRnSaQ
Old 10-15-2003, 11:58 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
you do know that the b18 has a more advanced head than the b16, b16 only has one vtec switch b18 has two.
just incase you didn't know.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 10-16-2003, 12:30 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: LS-Vtech
I would stay away from LS Vtech, since Vtech doesn't know anything about your car and specializes in baby toys and cordless phones... lol!
Sorry couldn't stay away from it.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 10-16-2003, 12:33 AM
91civicDXdude's Avatar
wtf are you talking about.. VTEC (not VTECH) is variable valve timing and lift, it has nothing to do with dual butterflies of the B18C1 intake manifold. there is only 1 "vtec switch". it is called the VTEC solenoid, or spool valve. The B18C1 has primary and secondary intake runners, which suck ass for high rpm power. this is why the B18C type R has only single runners. The B18C1 GSR intake manifold is made to heighten low rpm torque with very long runner, and then at 3,000 rpm or so, it opens up the secondary butterflies, which allows air to bypass the long runners and use the shorter runners for high rpm power. extra parts just means more weight and more things to break.
B16 head is where its at.
By the way, you will have to drill out the dowel pin holes in teh b16 head to accept the bigger B18 block-to-head dowels. Also, you will have to plug the internal oil passage, and then drill and tap another in the head for VTEC oil pressure, and run the other side off of a T from your oil sending unit, much like a turbo oil feed. Full Race has actually engineered stepped dowels so you dont have to bore out the dowel holes. do a web search for "full race LS VTEC".
Old 10-16-2003, 12:36 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
WHAT????
you know what honda does, they take a "B16" head, do a mild port/polish on it, put in some hotter cams and some better springs/retainers and throw it on the ITR.
they are the same, and vtec switch, you mean like switch form one lift setup to the other, only one car ever had 3 stages. some old civic where it was one valve low lift, other valve ALMOST none, then 2 valves low lift, then 2 valves high lift. all others are both valves low lift, then both valves high lift. ivtec im still not exactly sure of, i think theres stilla crossover point but the cam timing itself is infinitely adjusted by the computer throughout the whole power band(maybe)
anyways as far as headwork, you need to tap and plug the oil suply hole, on the back of the head, dist. side, heat up the plug and remove it, the dowel holes, enlarge to 14mm I think, same with the headgasket holes(headgasket for YOUR engine, not what the head came form) and then on the back of the block tap into the oil pressure sender and run a oil line to the back of the head where you removed the plug. also you need a vtec ecu and some wiring.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 10-16-2003, 12:38 AM
94tegRS's Avatar
well, by the time i posted mine 2 people already beat me to it, and as for the full race pins, b20vtec.com links to the full race site, and youi dont have to drill/tap a new hole, its already there, just plugged.
current
history:
I-VTEC is variable valve timing and lift plus the added benefit of electronically controlled cam timing. basically, the intake cam is retarded or advanced based on the sensors input to extract more power at all rpm.
btw, 3 stage VTEC was
12 valve mode
16 valve mode
16 valve high lift mode
Old 10-16-2003, 12:44 AM
94tegRS's Avatar
well, guess i knrew what ivtec was afterall.
anyways, I once read a write up about the 3 stage vtec and it said the non-operational ones before the 2nd stage kicked in still opened but just a TINY amount, I cant remember the reason it gave, but it had one, I think it was something about not upsetting the swirl process or some crap, dont really remember.
current
history:
Old 10-16-2003, 04:47 PM
thanks for all the info, but do you guys think the LS-vtec is worth the trouble, or do you think i should just go b16
KoRnSaQ
Old 10-16-2003, 05:53 PM
alky350 alky350 is offline
b-tek
i was thinking about doing a b16 swap, but lots of people say it lacks torque. im really steering towards an ls/vtec setup. they have lots of torque.
b-tek ownz joo!
Old 10-16-2003, 06:31 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
ls/vtec can be awesome but only under certain conditions. of course you need a head and block in good shape, then you need someone to do it right no half ass job on this one, and you cant beat it to holy hell thats the fastest way to blow it up. yea of course we would all drive it fast it would be too much of a temptation but some people just drive stupid they beat there car at all times and shed miles and miles off the life of their engine.
91civicdxdude is the bomb with all technical stuff, man you get so confusing, put a lil more simply the block and head dont match up and you have to run an external oil line.
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 10-16-2003, 06:37 PM
JLB87's Avatar
JLB87 JLB87 is offline
Re: LS-Vtech
12 valve mode
16 valve mode
anyone else getting a little confused? lol
Old 10-16-2003, 06:43 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
IF you rebuild the bottom end with some nice goodies, and i think a better girdle, you'll be able to use more of the powerband (ie: rev higher) than just slapping the head on there. and it will be more dependable. LS/VTEC is worth the money when done right good bottom and top end.
Old 10-16-2003, 06:47 PM
i know ive heard this before but i cant remember how to say it so im not gonna try can anyone tell us why the ls-vtec is not so reliable i think it has to do with compression or something, someone please enlighten us i would like to hear it said right again
Say NO to Primer!!
Old 10-16-2003, 08:45 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
2 reasons i can think of 1) R/S ratio is worse in the LS motors and 2) improper installs give things a bad rap, just like nitrous it is fine and will not hurt the motor if installed and used properly.
Ls 500 / Ls 600 zyajzarc LS400/LS430/Celsior 5 04-26-2004 03:39 PM
LS/Vtec or Turbo LS? Ricochet Integra 0 07-30-2003 03:36 PM
LS with turbo, or LS with LS/VTEC and Turbo IntegRocket32 Integra 3 10-11-2002 02:13 AM
88 ls ecu vs 89 ls ecu outofstep '71-'87 Civic | CRX 5 04-13-2002 02:41 PM
