Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-10-2002, 05:27 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
88 ls ecu vs 89 ls ecu
i got an offer to buy a 88 Ls ecu $20... im doing a ZC swap on an Si tranny, should i go for 88 or hold off for an 89 how much difrence is there bewtween them?
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 04-10-2002, 07:41 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Get it, it will work fine. There is really no difference in those two years that I know of.
Old 04-10-2002, 08:16 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
basically will work the same
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-12-2002, 08:32 AM
shadowboy's Avatar
shadowboy shadowboy is offline
Send a message via ICQ to shadowboy Send a message via AIM to shadowboy
there is ZERO difference between the drivelines (and computers) of 88-89 integras.
there is also ZERO difference between the ECU's of the various trim levels (so you can use an 88 or 89 RS ECU as well)
just be sure that the ECU is for the same type of transmission and that you do not use an 86-87 ECU for an EF ZC swap (for a 3rd gen civic/1st gen CRX be sure to use an 86-87 integra ECU, as the older ZCs are vacuum advance)
Shawn
1979 Porsche 924S
1987 Honda CRX HF -- Project Chassis
1989 Acura Integra LS -- Project Parts Donor
Old 04-13-2002, 01:31 PM
outofstep's Avatar
so if i get the 88 ECU what ZC should i get? i have a 90 CIVIC DX HB
what year ZC and Si tranny should i get?
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 04-13-2002, 02:41 PM
shadowboy's Avatar
get an EF (88-91) civic ZC, you could get an older ZC but it wont work with the 88 ECU. (unless its a black top g1 integra ZC) the older ZC will also not fit the mounts for the EF civic (so that means the black top g1 integra ZC wont be wise... its less common than the EF civic ZC anyway)
get any 88-91 civic Si tranny, or if you are really adventurous, use the ZC tranny, ZC gear clusters, but use the civic Si final drive (the ZC has a taller final drive for less acceleration, but the gear ratios are closer spaced)
using the ZC tranny will also give you equal length halfshafts
Shawn
1979 Porsche 924S
