Go Back   Automotive Forums Car Chat > Cars in General
Old 10-15-2003, 05:30 PM
mtdxx mtdxx is offline
Pinstripe removal
what is the best way to remove pinstripe? On one side of my car it looks as if it would just peel off with a razor blade, however on the other side, it looks like someone peeled off the top layer of it, but a thin layer is left stuck to the car, which I can't get underneath to scrape off.
it almost looks like it is part of the paint. Any suggestions on how to remove this?
Old 10-16-2003, 01:34 AM
BullShifter's Avatar
Re: Pinstripe removal
Dont use a razor blade. Heat with heat gun or blow dryer then remove. Use adhesive remover for any remaining glue. Followed by polish/wax or sealer.
The paint WILL be a different color where the pinstripe was. There is nothing you can do beside repaint the car if you want it to match perfectly.
Old 10-16-2003, 09:01 AM
hair drier or heat gun, where was my head! Thanks man.
Old 10-16-2003, 03:38 PM
There are also heated "razor blades", I wouldn't use that on anything besides glass. Why not just use glass cleaner & razor blade for glass(sticker removal)? Works fine for me, but your dealing with the paint.
http://topoftheline.com/eldecrem.html
Old 02-23-2004, 02:59 AM
qwas qwas is offline
Xylene
Use a hairdryer to heat and pull off the bulk of the stripe, then use a chemican called Xylene to remove the yukky goo. It won't harm your paint and can be found in the paint section of any hardware store. Works like a charm!
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
pinstriping removal bhw33191 Caprice 9 10-28-2008 05:38 PM
pinstripe removal ReiFreak Exterior | bodykits | Lighting 14 12-05-2006 07:06 AM
PinStripe Removal! TruDenali88 Accord/TSX/Accord Hybrid 4 03-02-2004 05:56 PM
unconventional pinstripe removal.... dreemkill '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 03-01-2002 11:28 PM
