Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-25-2008, 12:54 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
pinstriping removal
Im just curious if anyone has a better solution for removing pinstriping. I've been using this acry solution to sort of dissolve the old stuff. It takes forever to do and kind of dissolves my skin too .
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 10-25-2008, 04:12 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: pinstriping removal
Have you tried a hair dryer? Place the hair dryer over the pinstriping in sections and it should lift off the car pretty easily. Don't leave the hairdryer in place too long but rather move it continuously over the section of striping you want to remove.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 10-25-2008, 08:25 PM
mega420 mega420 is offline
Send a message via AIM to mega420
that is really the only way and after use wd40 to remove the residue
Old 10-25-2008, 11:51 PM
bhw33191's Avatar
Thanks for the help this solution sounds much easier. I'm not sure how good this would work though cause the pinstriping seems to have become a part of teh paint. I'll try it anyway though
Old 10-26-2008, 01:26 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Another thing you can try is a spray can of 'Sticker Shock' by KleenStrip (you can get it at Autozone). This loosens up decals, bumper stickers etc to be removed from a car (it really makes the job quick and easy). Plus, it works great on 'cooked on' pinstripe.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-27-2008, 12:44 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
There is also a rubber type wheel that you can mount to a drill to remove decals and pin striping.
I picked up one at a auto body supply.
Just be careful and use a light touch or it will burn through the paint.
Good Luck
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-27-2008, 02:09 PM
I was at my local A C Delco warehouse today picking up some filters for my vehicles when I noticed a display of products from the makers of PB Blaster. Apparently ,( for which I didn't know before,) this company has a whole line of products to meet various needs in both the automotive and small engine world, including a spray on product to remove decals, and pinstriping. If it's anything like the original PB Blaster then it should do a really good job. I tried to find it on their website, but couldn't at this time.http://www.pbblaster.com/productlist.html
Old 10-28-2008, 05:20 PM
also if the hair dryer dont work use a heat gun but dont let it sit on the paint to long or it will burn. but if your gonna paint the car just wire brush em off sand them prime and paint. i remember you said it was painted some ford blue give me the details on it and when it was painted and i might be able to help you mach the color.that way you can paint the trunk like you wanted.
Old 10-28-2008, 05:36 PM
bhw33191's Avatar
ok sweet i'll try and get some closer pictures of the paint. I think it was painted somewhere between 88-90 but i'm not positive. Its a two tone paint scheme as you might noticed in the pictures and i think the top lighter blue color is that Ford explorer light blue, but i don't think the ford explorer was out until 90 or 91 so now i'm not sure. i'll post a new thread with the pictures.
Old 10-28-2008, 05:38 PM
ok cause i was accually looking at some paint that was called ford light blue and ford dark blue lol
