Old 10-15-2003, 02:03 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
Question on switching heads and such
Well im going t buy an si head and throw it on my dx block i dont need the ecu right? i know i need the ecu if i convert it to multi point but what if im not going to do that, can i just buy the head and thats it? Also if i replace the head with a rebuilt head o miles then isnt that almost like the engine is rebuilt because there are not many problems from the block like ever so tell me what anyone thinks about that also
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 10-15-2003, 02:12 PM
crxpace crxpace is offline
if i were you i would just save up for a B16 and do the conversion yourself. It's really not worth it to do the head swap on the DX.
peace
Old 10-15-2003, 02:33 PM
nah dude, see i overheated my dx therefore im pretty sure i fucked the head over royaly i just need to get a new head so i can slap it on and SELL it!!!!!!!!
Say NO to Primer!!
Old 10-15-2003, 03:08 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I've had funny oil burning problems when I put a rebuilt head on a block with only 100k on it. It was a 86 civic, but I was told by a mechanic that the combination of new the new head parts and the old rings creates higher compression, and that somehow causes oil to get past the old rings.
I know that sounds funny, but it happened to me.
If I were you, I would try to get a used head from a junkyard that has close to the same milage on it, and slap that on.
Old 10-15-2003, 03:17 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Question on switching heads and such
yup...this is a very common problem when the head is rebuilt and the rings are left alone.. rings must always be done when putting new valve springs, seals, etc...
SOLD!
Old 10-15-2003, 03:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
along with what marked001 said i would also like to add...
when it over heats not just the head gets fucked. the bottom end can warp as well. if the bottom is warped and you stick a different head on (rebuilt or not) you take the chance of the gasket not sealing. you would have better luck sticking the warped head back on...at least it's warped the same. BUT...why would you want to rebuild a warped head to stick back on a warped block. LMAO
throw it in the gutter...go by another. in the words of dropshop "d stands for disposable"
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-15-2003, 03:27 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Hi, Lisa.
I've spent the last three weekends installing a used head on my 86 Integra, which is a D16A1 motor...except for DOHC, it's the same as yours (minus a few ccs).
After working my ass off getting the old one off and putting the other head on, I don't think it was worth the time and effort.
I spent $200 on gaskets(Head gasket, intake and exhaust gaskets), new water pump, timing belt, heater hoses, etc. Plus the $150 I spent for the used head (they are hard to find, so I had to take what I could get.)
Now that I've found one in a junkyard, I could have bought an entire motor for $200...plus $50 for a water pump, $40 for a timing belt...
Anyway, because the gaskets are so costly, you could install an entire engine for the same price.
Plus, you could be done swapping one D-series motor for another one in a day...instead of screwing around for six days trying to replace frickin' head.
Flunky
PS-I paid extra for Beck Arnley gaskets...they cost a bit more than what Autozone had in stock, but a little extra money for critical parts is worth it, in my opinion.
Old 10-15-2003, 03:29 PM
AF Premium User
You can keep the DX ecu if you do the MPFI swap and install a resistor box.
The SIs do indeed have a different ECU, and you'll want it eventually.
Flunky
Old 10-15-2003, 04:38 PM
hmmm well i guess i should replace the whole engine then it had like 207k miles anyway its tims to put her to rest hehe
anyone want to sell me their si or dx engine!!!!!!!!!!!!
Say NO to Primer!!
Old 10-15-2003, 04:57 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Question on switching heads and such
so true, i warped the block and head when i blew my head gasket last year. i just replace the whole engine with one from attarco in berekley ( engine was $275) if you need one right away i would go to them, i think its only like $225 now... they are low mileage replacement japanese motors...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-15-2003, 05:57 PM
BullShifter's Avatar
You can have my ZC SOHC for $25,000! Nah, make it $30,000.
If you do put a head on, check the engine block with a true-bar, there should be no more than .002 gap. Not much room to mess with. Fuck a 4-banger, throw a 5.7L LT1, LT4, LS1 in it.
Old 10-15-2003, 07:08 PM
Re: Re: Re: Question on switching heads and such
thats cool and everything but arent you having problems smogging now?
Say NO to Primer!!
Old 10-15-2003, 07:15 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Re: Re: Question on switching heads and such
thats not the engines fault. its my cat being dead..im 99% sure. the engine you buy from them is basiclly just the block and head, no dizzy, intake manifold, exhaust manifold, etc..
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 10-15-2003, 11:48 PM
91civicDXdude's Avatar
Flunky
judges??? WRONG. sorry, the DX ECU is made to fire 2 non sequential injectors. It doesnt have the capacity to use a cylinder position sensor, crank angle sensor, or fire 4 injectors; sequential or not.
bottom line... MPFI with a PM5/PM9 ECU will run on two cylinders. I know this from personal experience, back when i didnt have a clue about that kind of stuff.
Old 10-16-2003, 01:39 PM
AF Premium User
I cannot speak from experience in this matter.
I haven't done the MPFI swap, although I very seriously considered it. I even bought the intake manifold for it, but sold it to another member when I needed cash.
I was going by the "How-To" information here:
http://www.4thgenerationcivic.com/
on Ami's site. I didn't see anything there which said you needed to upgrade the ECU as well.
Flunky
Switching Bright and regular head lamp Danizzle987 Camaro Discussions 8 02-06-2006 03:42 AM
and it begins.... (pics and such, 56k beware) Miataracer Engineering/ Technical 29 03-13-2004 07:48 PM
quick question about relays and such 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-13-2004 01:54 PM
please explain coil-overs and shocks and such tynebeach Tires and Wheels 8 10-11-2002 02:12 PM
question about head and tail lights Thing-A-Majig Car Modeling 5 02-04-2002 05:44 AM
