Old 02-04-2006, 09:10 PM
Danizzle987 Danizzle987 is offline
Red face Switching Bright and regular head lamp
Ok this thread may prove my lazyness, but here it goes... I had a head light out, so I took the bright bulb from the same side and just put it in the head light position. This wasn't ment to be a permanant fix just something to keep me from getting pulled over While I get around to getting a new bulb. (btw how much will one of these cost?) The only issue I ran into was that there was an extra wire, well actually its a double wire that I just put a piece of electrical tape around and ignored... Question 1: (or two for those of you keeping count) Is this the wrong thing to do Question 3: It seems to work fine will this cause serious/permanent damage to my electrical sys. or something? I am going to avoid driving at night until I get a clear responce (and I doubt it will take long before I get told what an idiot I am) Thanks
(1990 z28 rally sport)
Old 02-04-2006, 09:23 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Switching Bright and regular head lamp
Just get the regular one that is suppost to be there.
Old 02-04-2006, 09:38 PM
Lightbulb Re: Switching Bright and regular head lamp
Sorry I guess I should have mentioned I am Lazy and Broke. So I am (obviously) going to put off any non-emergency expences as long as possible, or at least until I find a steady job (kinda helps) but yes putting a regular bulb in would be the proper solution, thx for da reply tho
Old 02-04-2006, 09:39 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
the bulb is only like $5 or something.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-04-2006, 09:49 PM
Good to know lol guess I did a lil extra work than needed, but eh It felt good to be a "problem solver" again... man I really need a job lol thanks 97c.
Old 02-04-2006, 09:57 PM
97cavalier's Avatar
oh you have a 90? i think you can still just get a bulb insted of the whole lamp, ya i think you can, don't see wht not.
Old 02-06-2006, 03:36 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
No, he's going to need to get a whole new lamp. His lights are sealed enclosures with the bulb inside the lamp. It'll probably cost you anywhere from $15-$20 for a new one. Depends which brand and type you buy. I would try to help you out with your issue, but honestly I have no clue what you're talking about.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 02-06-2006, 03:42 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
nope, i just had to replace a lamp, bought the entire lamp for just over 6 dollars at advance... was so cheap i got 2 and replaced both...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
oh and you can't just buy a bulb...
