Old 10-14-2003, 12:39 PM
WindyIce's Avatar
WindyIce WindyIce is offline
Send a message via ICQ to WindyIce Send a message via AIM to WindyIce
Problems with Coolant.
Well I started to notice a black mark on the top of my hood the other day. This is in my 91 hatch and the mark was right above the timing belts. I could not find anything leaking around the area but yesterday my car overheated and I find my radiator is dry. So I was testing it out his morning and when I start to rev the motor alittle I can see a spray of radiator fluid coming from the timing belts. Does anyone know what is wrong?? I can't really see where it coming from with out getting a splash of hot raditor fluid in my face which HURTS!!!! ARG!!
Thanx
Windy
P.S. I still have my crappy stock motor if that helps With my poor b16 sitting there waiting to be dropped in
**!!4thgen in the projects!!**
B16A LSD JDM With Entire Car
Old 10-14-2003, 12:42 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
sounds like a water pump if its leaking coolant over by the timing belt. Sounds like good as time any to swap the b16 in...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
problems with coolant system adamdell Clio/Clio II/Clio III 1 01-23-2006 05:38 PM
Problem with Coolant Light MoshimoGTP Jetta/Vento/Bora 7 11-09-2004 06:40 PM
99 Jetta problem with coolant sensor som1dies2nite '97 - '03 3 08-26-2004 12:48 PM
Problems with coolant sensor Tidus05 Regal 2 07-31-2004 02:50 PM
problem with coolant level marosjanac Lumina 2 11-20-2003 09:33 PM
