Old 11-16-2003, 03:55 PM
marosjanac marosjanac is offline
problem with coolant level
i had recently add a galon of coolant to a coolant tank, it was exactly on 0ct 28, today i checked coolant and the level is lower than its supposed to be, can somebody give me an advice what can be wrong, at the time when mechanic add coolant, they also replace a water pump, because it was leaking
Old 11-16-2003, 03:58 PM
Re: problem with coolant level
0n oct 28 mechanic added a coolant to my car, it was a gallon, but i checked today coolant, today is nov 16 and level is lower than its supposed to be, mechanic also replaced a water pump, because it was leaking, can somebody give me an advice, what is wrong, or what to do
Old 11-20-2003, 09:33 PM
7T9Shark 7T9Shark is offline
Check your oil. You may have a leaking manifold gasket, which is allowing coolant into the oil. Remove your oil filler cap and if you have a bunch of white gunk inside of the valve cover, that's it. This is a very common problem with the 3.1 V6 because they have aluminum cylinder heads.
Trail EXT - Problem with Fuel Level Indication ibelta TrailBlazer | Trailblazer EXT 4 04-03-2011 11:45 PM
Problem with Coolant Light MoshimoGTP Jetta/Vento/Bora 7 11-09-2004 06:40 PM
99 Jetta problem with coolant sensor som1dies2nite '97 - '03 3 08-26-2004 12:48 PM
Problems with coolant sensor Tidus05 Regal 2 07-31-2004 02:50 PM
Problems with Coolant. WindyIce '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-14-2003 12:42 PM
