Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 11-07-2005, 07:31 AM
adamdell adamdell is offline
Unhappy problems with coolant system
ok, i seem to have solved my last problem with the loss of power but i now have a new problem that surfaced this week. the cars coolant is disappearing without any visible signs of a leak! i drive it for bout half an hour and the coolant resevoir is virtually empty and was full when i left at the start of the journey. the coolant mixture has turned a rusty brown colour also and i can hear what sounds like what flowing/bubbling from within the cockpit of the car, down towards the passenger footwell. any ideas of what the problem might be and any solutions, cheers adam
Old 01-23-2006, 05:38 PM
chriskirk10 chriskirk10 is offline
Unhappy Re: problems with coolant system
I had same problem, and it turned out to be headgasket gone.
check for sighnes of yellow gunk under oil cap or may be an air lock
try venting radiator when engine is hot, or could be a cracked block.
also check under water pump for leaks.
