Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-13-2003, 08:00 PM
TidalWave4 TidalWave4 is offline
Strange Problem
My brother recently handed me down a 1993 Nissan Altima that has been having some problems lately. The first week i had it, it was fine. A couple of days ago i was driving down a main road and all of a sudden all the dash lights turned on, my steering locked up (because i lost power steering), and the gas pedal stopped working. I had to pull over to the side of the road and switch off the car. I switched it back on and it worked fine again. This has happened two more times since then. Does anyone have any suggestions as to what i should check out?
Old 10-25-2003, 08:48 AM
gimpy257 gimpy257 is offline
Re: Strange Problem
Did u check the battery connections. Same thing happened to my car... the mechanic didn't connect the battery terminal correctly after inspection. It could be loose
Old 11-03-2003, 06:00 PM
I'm not sure it's a problem with the battery. I think i'm going to get my fuel pump checked out because the gas stops working when this happens. The lights, radio, and everything else electrical, including the brakes, work fine when the car shuts down.
Old 12-03-2003, 04:18 PM
addicted2macs addicted2macs is offline
I had similar, if not exact, symptoms in my Honda when the timing belt broke. But, it definitely wouldn't start back up.
I'm pretty sure the Altima has a timing chain, so that's not your problem. Could it be in the timing, though?
Not much of a mechanic, so don't laugh too loudly....
92 Ford Tempo strange problem beigecar General Discussion 12 12-10-2004 11:06 PM
Strange Problem with the Speedometer. SEARCHER Maintenance 0 07-25-2003 12:35 PM
strange problem dumbfounded Cavalier 0 07-10-2003 01:56 AM
Strange Problem......help! idolsword Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 05-08-2003 01:18 AM
My G has another strange problem...someone help please DJ Hotpokit General 5 09-20-2001 12:06 AM
