Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 07-24-2003, 06:10 PM
beigecar beigecar is offline
Unhappy 92 Ford Tempo strange problem
My 92 Ford Tempo always starts to shake and die after running with brake half-pressed for 20 seconds, i.e. backward parking, slowly go in a car jam. But if i stop it and give some gas, it becomes normal again. Does anyone have any idea? Thank you in advance.
Old 07-24-2003, 07:26 PM
DaGr8Tim DaGr8Tim is offline
Could be a vaccum leak, could need a tune up, start with the basic things.
Plugs, wires, cap, rotor, oil change, 02 sensor, ect. Do you have a check engine light?
Even if you don't you may still have a code in the memory.
Owner 1988 Ford Tempo GL
Owner 1989 Mercury Topaz LTS
Owner 1991 Mercury Topaz GS
Owner 1994 Plymouth Voyager
www.tempotopaz.com
Old 07-25-2003, 09:26 AM
pcv pcv is offline
DaGr8Tim is right. You possibly have a vacuum leak. There is a Tee next to the brake booster along the firewall with 4-5 hoses and stoppers on it. Make sure they are all there and are not leaking.
Check all vacuum hose. Move them and look at them to make sure they are not cracked/leaking.
NOTHING LIKE AN OLD CAR.
Old 07-25-2003, 03:56 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Could also be a bad power brake booster. Sometimes they will develop an internal vaccuum leak.
Old 07-27-2003, 01:43 AM
Supra-Devil Supra-Devil is offline
Send a message via AIM to Supra-Devil Send a message via Yahoo to Supra-Devil
how old is this car
Old 07-27-2003, 04:07 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 92 Ford Tempo strange problem
Originally posted by beigecar
My 92 Ford Tempo
Originally posted by Supra-Devil how old is this car
i dunno u tell us supra devil
josh
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-10-2003, 08:25 PM
Thank you for the reponses. I have the brake checked and no leak was found. But i am confused too, since this problem has lasted for quite a long time (around 6 months), if there is a leak, the vaccum should be exhausted, no? I am a person with little knowledge about the mechanism of cars. Can anyone give me some more explanation? Thank you.
Old 08-11-2003, 11:59 AM
pcv pcv is offline
You checked for a brake leak. That will effect your brake pedal going down and loosing brake pressure. In other words, you will not be able to stop effeciently.
As soon as you start the engine, vacuum is created by the engine and is required to run your vehicle. If it leaks, then you will have a problem like the one we suspect you are having right now. Your idle control valve can also cause the same problem. If you know a good shop, take it there and get them to check it out.
Old 10-07-2003, 02:03 AM
VRSenator VRSenator is offline
parking
To start with how the hell does it take you 20 seconds to reverse park i think that about 4 secs outta do it................
maybe you should try not holding the brake on so long that could help...
LiVe HaRd DiE sIdEwAyS
Old 10-07-2003, 02:41 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Best thing to do is to read any codes the EEC-IV computer may have stored.
Come see us at www.tempotopaz.com for a GREAT tutorial on how this is done! Do you have a Haynes or Chilton's manual for the car?
Old 11-09-2003, 08:47 PM
bleeshort bleeshort is offline
Send a message via AIM to bleeshort
brakes
ho buddy if you had no power brakes you would still have manuel brakes so its got to be your brake cylyders
Old 11-11-2003, 05:49 PM
Chrisser Chrisser is offline
ho buddy if you had no power brakes you would still have manuel brakes so its got to be your brake cylyders What ? lol
what do the brake cyl have to do with the engine idleing rough ???
Old 12-10-2004, 10:06 PM
jw_8890 jw_8890 is offline
Send a message via AIM to jw_8890 Send a message via MSN to jw_8890 Send a message via Yahoo to jw_8890
I don't know about the brake thing but u may want to check ur fuel pump &/or filter.
2.3L 1994 ford tempo engine problems! kyleholt11 General Discussion 14 03-03-2006 06:05 PM
1991 ford tempo temperature problem cokekid General Discussion 5 09-05-2005 04:10 PM
89' Ford Tempo Fuel Problem Oldtemp General Discussion 3 09-05-2005 03:43 PM
