Old 10-10-2003, 02:34 AM
DArkforces9 DArkforces9 is offline
Send a message via ICQ to DArkforces9
Question Dx and STD
This has probaby been asked before, but i couldnt figured out what words to use in the search to find anything. Heres my question what does the dx have different motor wise that it makes 25 more horsepower over the std?
Old 10-10-2003, 03:02 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
I have a STD model with 2.25 in. exhaust from the manifold back and i've never had a problem beating a DX. I just thought the only difference was the transaxle being 4speed as apposed to 5speed. I may be wrong though.
Check out my car here My 91 Hatch
Old 10-10-2003, 03:33 AM
91civicDXdude's Avatar
you are wrong.
the STD has a couple differnces, the main ones being in the throttle body assembly. In the STD and DX, there is a primary "choke plate" thing before the actual throttle plate. in the DX, it opens all the way, while in the STD it only opens about 2/3 of the way. also, underneath the throttle body there is a spacer plate. on the DX, it is port matched to the throttle body exit. on the STD, it is noticeably smaller.
Also, the DX has a PM5 ECU, whereas the STD has a PM9. Im not 100% sure on the specifics of each ecu, but im willing to bet money that the PM9 is a detuned PM5.
Old 10-10-2003, 10:46 AM
I am also using the ecu from a dx so i guess that would make a little difference. Either way i'm goin b16 soon anyways so I really don't care. Thanks for the insight though. Ya learn somethin new everyday.
Old 10-10-2003, 11:03 AM
thanks for the replies unfortunatly it doesnt look like theres a quick change to get that std to dx hp.
Old 10-10-2003, 11:14 AM
yes there is. the quickest way would be to swap for a DX throttle body, but you can temporarily remove the top pre-throttle plate and use a DX ECU. that still leaves the restrictor plate under the TB, but you need one from a DX to swap it with.
Old 10-10-2003, 11:17 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Dx and STD
I Probably Need To Do That
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Tuned.com's Fast and Furious Release Party and Car Show April 3rd and 4th HotCtyPlaya North East 2 03-28-2009 04:32 PM
ext and std cab mounts cdnbambam C/K 1 02-17-2006 05:05 PM
how to tell differnce wiper motor hide and std. 72 chevelleconv. Chevelle 3 03-01-2005 12:00 PM
Difference between a GT and std coupe? 67coupe Mustang Talk 7 05-08-2004 05:42 PM
knuckles and hubs for std model b16 swap lowboy '88 - '91 Civic | CRX | Wagon | Shuttlee 10 11-03-2003 11:48 AM
