Old 12-06-2001, 10:29 AM
Lee_J Lee_J is offline
Turning a regular Bike into a Motor Bike (very interesting, read)
hey,
i was thinking one day... I was like, that would be cool if i could put a motor in that bike and make it go...
Is this possible? I want to put a motor in a regular bike, and be able to drive it....
Tell me if this is possible, and tell me what i'd have to do to make this come true...
It may sound dumb... But i think this would be cool to do.
Old 12-06-2001, 10:46 AM
enginerd's Avatar
enginerd enginerd is offline
I've done this years ago. Find a small, two stroke engine (weed-eaters/ small motorcycles/ and leaf blowers are good sources). Fab up a bracket in the "V" of the frame under the seat to mount the engine. I used a smaller sprocket pressed on the engine and the main sprocket was from a ten speed so the engine connected to the sprocket with the pedals and sprocket with the pedals was connected to the rear wheel. Get some front pegs to rest your feet on while the engine is running (so the moving pedals don't hit your feet, or you can pretend you're pedaling). Remove the starter rope from the engine and re-locate the ignition switch if neccessary. Move the throttle to the handlebar (a simple lever from a gear-changer off a ten speed will work) Now when you want the engine to do the work, simply switch the ignition on and pedal to start the engine!
P.S. Be careful starting the engine. While the kickover isn't enough to seriously hurt you, the pedals can spin around quickly and scrape your legs.
Old 12-06-2001, 12:53 PM
hey, do you have aim? because i need to talk to you about this, because i am gunna start on this project soon... thanks
Old 12-06-2001, 02:57 PM
enginerd's Avatar
No, but feel free to e-mail me at [email protected] with questions.
Added regular gas into a Diesal fuel tank... sputacus Engineering/ Technical 6 07-30-2005 01:22 AM
Very Interested in Mitsubishi Eclipse Mitsclipse97 Off-Topic 8 03-20-2005 12:14 AM
Very Interesting sex topic... blacksnake98 COMPLETELY off-topic 20 11-29-2001 07:24 AM
