Old 07-28-2005, 10:58 PM
sputacus sputacus is offline
Added regular gas into a Diesal fuel tank...
I added gas to my diesal truck by mistake...about 30 gallons in a 33 gal tank. Drove about 12 miles before I realized it.
What should I do???
Thanks!!!
Old 07-28-2005, 11:01 PM
x_skaven_x x_skaven_x is offline
Send a message via MSN to x_skaven_x Send a message via Yahoo to x_skaven_x
Re: Added regular gas into a Diesal fuel tank...
empty your tank right away
Old 07-28-2005, 11:04 PM
Re: Re: Added regular gas into a Diesal fuel tank...
Will do!!!
Old 07-28-2005, 11:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Also have the tank and the fuel lines flushed. This is a job for a professional diesel mechanic.
Gasoline in a modern diesel engine will destroy the seals in the injectors and often in the injector pump as well, quite quickly. Repairs can run $600 - 1000 if this happens. Fix and flush it now and you might get away with minimal damage.
Old 07-29-2005, 09:30 AM
widebodyscotty widebodyscotty is offline
I accidently put diesel in a gas E-150 van once. She didn't run too well!
Old 07-30-2005, 01:19 AM
The Dude The Dude is offline
The problem with running Gasoline in a diesel engine can be bad. Diesel fuel does three things for the Fuel system. Cleans, Cools and LUBRICATES. Gasoline does not lubricate very well at all. Problems with injectors, pumps, all the mechanical fuel components in your engine can be severly damaged if you run it for to long. You will have more problems than just seals if you ran to hard.
Old 07-30-2005, 01:22 AM
So if i were you i would drain the tank put diesel back in and see if you start having excessive smoke or major loss in power. If it runs fine you are probaly ok, but you lessened the life of your components.
