Old 10-08-2003, 08:34 PM
igotageo igotageo is offline
Geo Metro/Civic Engine Swap
Does anyone know if i could fit any kind of Honda Civic engine into a 96 3 cylinder 1-liter Geo Metro. I want to be sure before i try anything,Cuz i cant find any parts for the stock engine. Please help me out before i go crazy
Old 10-09-2003, 09:43 AM
odie13 odie13 is offline
you will also need the Honda transaxle, make custom motor mounts, custom wire the Honda ECU into the Geo wiring harness, custom CV axles.
You're better off trying an I4 geo motor form an LSI.
No where near as much power as the Honda but much easier to do.
Try a Suzuki Swift GTI motor. This has been done before.
Old 10-09-2003, 01:21 PM
geozukigti geozukigti is offline
I took a Suzuki Swift GTi motor and dropped it into my 3cyl metro convertible, and I can smoke honduh's with it, go with the swift 1.3 DOHC motor.
Old 10-09-2003, 09:24 PM
Where can i get a swift engine from? Would it be a pain in the ass to get in in without a lot of custom work done? Would i need new motor mounts for it, or would it be ok on the origonal ones?
Old 10-11-2003, 07:42 PM
It's mostly all bolt-in. You'll need the motor, wiring harness and ecu, fuel pump, drive axles and mid axle, gauge cluster and dash harness, engine mounts, front wheel hubs and brakes. You'll also need bigger rims to fit around the much larger GT brake calipers and rotors. It's a lot of work, but well worth it.
Old 10-11-2003, 08:35 PM
How much did that cost you? Is it all necassary or is there some things that i dont need?
Old 10-12-2003, 11:01 PM
It's all needed. Stock fuel pump will pump nowhere near enough fuel, stock axles will snap like twigs with the power and torque, and the GT axles are equal length, so almost no torque steer, wiring harness is needed with the ECU, and wheel hubs are much larger to fit with the larger axles, and the GT brakes fit on the GT hubs. It all ties together, so you'll need all those parts. Cutting corners is not something you'd want to do with a major project like a motor swap.
Old 10-13-2003, 09:46 PM
Does anyone know a web address where I can get all that stuff(new).
Old 10-24-2003, 10:16 AM
Only place you're gonna get it new is from a dealer, or an engine rebuild shop. If you want new, buy from the junkyard, and rebuild.
Old 11-02-2003, 07:05 PM
If I were to put the 1.3 swit engine in would I need new motor mounts or would the origonal ones be in the right spots to hold it up?
Old 06-13-2004, 03:56 AM
v8mazdaduz10s v8mazdaduz10s is offline
i would personally love to see a b16 powered geo metro!! i bet it wouldnt be that hard if you can weld and fabricate......hmmm
Old 10-02-2004, 10:40 PM
Staypuff Staypuff is offline
Re: Geo Metro/Civic Engine Swap
well funny thing a friend and i were dicussing how a mid mounted v8 engine and rear wheel drive with a forward 7 speed trans would be the best metro alive. besides needing to sup up everything so it doesnt snap in half and have way to much time to do it, you would be goin faster then anyone period. o yeah just dont hit anything or you will die
Old 10-06-2004, 05:08 PM
chembrad chembrad is offline
geozuki, why not just go with a Swift G10 1.0L 3cyl? Then you could reuse the metro axle/brakes/etc.
It sounds like the guy just wants a drivable car and not a torqued-out-Honduh-civic-embarassing car.
It would be funny to see the looks on a civic owners face in the rear view though. Especially if your metro is an old style looking 4 door hatch...
Old 10-10-2004, 09:58 PM
ReD_ReBeL_HB ReD_ReBeL_HB is offline
could a CRX motor fit in a Metro ? & if so how fabrication would be needed? what all would i have to do?
Old 10-10-2004, 11:17 PM
You can fit anything in a metro. Just a matter of how good of a fabricator you are. Honestly, if you have to ask if it'll fit, don't even try it. You'll end up knee deep in problems from wiring to motor mounts, to drive axle lengths. Replace the G10, or G10 turbo, or G13b SOHC or DOHC. They all fit, and have all the bolt in parts necessary for installation, without heavy fabrication.
2009 civic engine in a 95 Crazy667 JDM Motor & Parts info/chat 5 06-27-2016 02:12 PM
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
96 geo metro crankshaft pulley bolt keeps snapping krayziemike4202 Metro 5 11-16-2009 05:38 PM
1997 Geo Metro LSI 4Cly Auto shitfing Problem Zechariah Metro 2 09-28-2009 07:09 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
