Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-08-2003, 07:20 PM
bone_stok_civic_91 bone_stok_civic_91 is offline
Send a message via Yahoo to bone_stok_civic_91
Question my lowered civic
Can somebody please help? i bought my car about 3 months ago. the car was already lowered about 2 inches. spring were NOT replaced with lowering springs. they cut the stock springs. Feel is great but tires wear from new to worn out (showing metal) from negative camber in about 5000 miles. What special parts do i need? Can I shim? $$$ is kinda tight. if i can shim some how-to help would be appreciated. Thanks
Old 10-08-2003, 07:33 PM
NOSAJ's Avatar
NOSAJ NOSAJ is offline
Get ya a camber kit off ebay. The shims seemed less reliable to me because I thought it would weaken the strength of the stock bolts by using less thred, so I went with the kit. Yeah it cost a lot more than some washers but you get what you pay for. I had the same problem and installed my kit last weekend and my camber is now zero degrees.
Peace,
Nosaj
Old 10-08-2003, 07:47 PM
Re: my lowered civic
Peace,
Nosaj
is there a certain kit i should go with or are they all pretty much the same?
Old 10-09-2003, 07:36 PM
NOSAJ's Avatar
some thing like DropZone Front/Rear Camber kit 88-95 Civic
search ebay 'civic camber'
Old 10-12-2003, 06:12 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Cutting the springs is totally stupid and unsafe.
If you can save up from some replacements.
As far as a camber kit up front, the easiest to install yourself, is the Skunk2 kit which would run you around 190$
M.Sanew - AutomotiveArticles.com
Old 10-12-2003, 07:29 PM
civicrunner civicrunner is offline
I agree with him. Cut springs are very stupid. I have heard of idiots who cut their springs and hit a hard bump and the spring and all ripped through the hood. You might want to replace those asap.
A lowered Civic needs a Camber kit?? llaznthug Wheels/Tires/Suspension 5 02-10-2005 09:30 AM
Lowering Civic Si 2004 DacusAccord Wheels/Tires/Suspension 2 09-13-2004 11:35 AM
finding KYB shocks for lowered civic.. iceman822 Tires and Wheels 1 06-22-2004 11:48 PM
lowering civic? bluemoon541 Wheels/Tires/Suspension 6 04-19-2004 01:15 PM
lowered civic? bluemoon541 Exterior | bodykits | Lighting 8 04-18-2004 01:20 PM
