Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 02-09-2005, 12:57 PM
llaznthug llaznthug is offline
Exclamation A lowered Civic needs a Camber kit??
I have a '94 Civic Dx and thinking about lowering it on '17 inch rims. It should look phat as hell, but was wondering if the lowereing springs will cause negative or positive camber??
If so, where could I find a camber kit for my car and how much would it cost? Is it easy to install or should I get professional help? Provide links!!...if possible
Need help...any suggestions will be great!
Old 02-09-2005, 01:51 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: A lowered Civic needs a Camber kit??
When you lower a car you get negative camber (tops of the tires tilting inward).
Some negative camber is prefered as it makes the car corner better. Anything more than a 2" drop I recommend a camber kit. I'm actually dropped about 2.25" and run about -2.5 front camber and -1.8, since I autocross alot. My tires wear evenly.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-09-2005, 03:21 PM
im just going for looks...so any links would be great. i need to see wut it looks like.
is installing a camber kit impossibly hard or can i do it myself? if so, wut do i need to do?
Thanks for the help!
Old 02-10-2005, 12:47 AM
BullShifter's Avatar
WWW.GOOGLE.COM
Old 02-10-2005, 03:30 AM
mango1 mango1 is offline
Send a message via ICQ to mango1
skunk 2 camber kits are easy and they come with instructions all you really need is the tool to pop of the stock parts but you will need to get your alignment ajusted cause your toe will be mess up and they can fix your camber at the same time. tops to install a camber kit should be 45 to an hour
Old 02-10-2005, 09:30 AM
94hondaacc 94hondaacc is offline
It Would Cause A Negative Chamber But This Depends On How Drastic The Drop. Drop The Car First Then Take It To Get A Wheel Alignment, They Will Be Able To Tell You If You Definitly Need A Chamber Kit Or Not. I Think After More Than A 1.75 Drop You Need A Chamber Kit.
