Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 04-16-2004, 11:28 AM
bluemoon541's Avatar
bluemoon541 bluemoon541 is offline
lowering civic?
i want to lower my 96 civic...
at what point do i need to aquire camber kits?
how low?
Old 04-16-2004, 12:40 PM
PhiberOptik's Avatar
PhiberOptik PhiberOptik is offline
Re: lowering civic?
there are a lot of posts on this but most people generally say 2" or lower you will need a camber kit. The best thing to do though is put it on an alignment machine after the drop and find out how off your camber is. Peace
99 Civic EX
Si Spoiler
Type R mesh grill
Old 04-16-2004, 06:21 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: lowering civic?
Yup consensus says about 2" I've been dropped 2.5" with 0 toe front and rear. I believe toe wears out tires quicker than camber.
But I also autocross alot
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-16-2004, 07:45 PM
toe?
Old 04-18-2004, 12:09 PM
BullShifter's Avatar
Re: lowering civic?
I agree with CivicSiRacer
Easy to describe toe. Stand up & look down at your feet. Point your toes in = Toe in / Turn your toes out = toe out . Slight changes in alignment can have dramatic positive or negative affects on handling. "Alignment" is very difficult & lenghtly to explain fully, before you can understand that you must first understand slip angles, bump steer, & all that good stuff.
Old 04-18-2004, 04:00 PM
any suggestions as to which camber kits i should get?
from who?
Old 04-19-2004, 01:15 PM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
Get Ingalls or Skunk2.
Those are the only 2 that replace the entire upper control arm. Progress and others make you press out the ball joint and is a HUGE pain in the ass...
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
