Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 10-08-2003, 01:45 PM
costa510 costa510 is offline
Acheiva Water Problem!!
I have a 92 Acheiva and long story short... The leaks water all over the place...
Water seems to be welling up under the carpeting. the floor boards are sealed tight and I've replaced the door seals. I am wondering if it is the popup sunroof and if so how is so much water getting to the floor without the seats getting wet?
Is it possible that water is leaking into the ceiling and down through the side pillars then onto the floor? I know thats far-fetched but you have to be creative with this car to catch problems before they drain your savings. (cylinder head+head gasket)
This is just another in a long string of problems. The car only has to make it til April... Any help would be great....
Old 10-09-2003, 06:33 AM
bustedratchet bustedratchet is offline
Re: Acheiva Water Problem!!
Do you use the a/c on the car ? could be a clogged drain tube under the hood. Could be a leaking winshield seal could be a leaking cowl if your sure its water and not coolant and only getting on the floor if you cant find the leak and you only have to get to April. Drill a small hole through the floor in the lowest piont and let it drain.
Big Water Problem joelongnecker Ninety Eight 2 10-02-2004 11:01 AM
Electrical/Water Problem? houseofspam Intrigue 0 07-09-2004 09:04 PM
'88 big water problem JScot Cherokee 0 11-26-2003 08:50 AM
BAD water problem!!! lowboy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-03-2003 08:57 AM
little water problem... threethirteen Engineering/ Technical 4 02-26-2003 08:33 AM
