Old 10-05-2003, 10:28 PM
01accordster 01accordster is offline
Send a message via AIM to 01accordster Send a message via Yahoo to 01accordster
01 i need to reach 200hp!!need expert advice on mods.
Hi, I have a 2001 accord LX 4cyl. and im just beginning to fix it up, so far i have aem cai, d/c ceramic 4-2-1 sport headers, and an apexi N-1 exhaust system! But the problem is I dont know what else i should get that could help me increase my performance w/o having to add fuel injection system or ecu chip or any of the turbo stuff!!my goal is to reach 200!!your advice is much needed!!thx alot
Old 10-06-2003, 12:05 AM
92lx 92lx is offline
without ripping your engine apart and totally rebuilding it, or without nitrous....you won't be seeing 200hp anytime soon. I forgot what the 01 power rating for the 4 cyl is, but I belive it was like 150ish.......no amount of bolt ons, or even minor head work is going to get you up to 200hp at the crank......nitrous is about the only way, but I think you meant to rule that out already.
- Nathan
Old 10-06-2003, 12:07 AM
njaccord's Avatar
njaccord njaccord is offline
Send a message via AIM to njaccord
i'd swap in an h22. that'll put you at 200hp and u don't need a turbo!
'97 Honda Accord LX Sedan
-Eternal Blue Pearl paint
-Clear lenses all around
-Tinted windows 35% all around
-Street Glow blue neon dome light
-Indiglo gauges
-Carbon fiber dash trim
-Kenwood MP3 head unit
-Pioneer speakers
-Front upper strut bar
-Tein S. Tech springs 2.1"F/1.7"R
-KYB AGX ajustable gas shocks
-2 1/2" straight pipe cat-back exhaust
Old 10-06-2003, 08:05 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
I'd say go with an adjustable cam gear and get a port polish, that might get you up there.
1995 Honda Accord LX...all stocked out!
http://www.cardomain.com/member_page...page_id=356187
Old 10-07-2003, 06:47 AM
what do you mean by polish port?
Old 10-07-2003, 09:20 AM
akina_speedstars akina_speedstars is offline
Re: 01 i need to reach 200hp!!need expert advice on mods.
Polish or smooth the inside walls of the intake manifold; or machine the inside of the cylinder head for smoother intake and exhaust port chambers.
The mods that you have done just squeeze out a little better performance hp-wise, almost zero torque-wise. The increase you desire is quite drastic for any car and, in your case, can only be achieved by 1. increased engine displacement, 2. nitrous oxide, 3. turbo-charger (I don't know of any company that makes a super-charger for the Accords).
Old 10-07-2003, 09:28 AM
so would the adjustable cam gears increase my car performance?
Old 10-07-2003, 07:59 PM
As long as you know what your doing when you adjust the valve timing. The disadvantage of messing with valve timing is that you can make the car have a rough idle.
If you don't know much about valves, camshafts, and timing I suggest reading this: http://auto.howstuffworks.com/camshaft.htm
Old 10-07-2003, 09:47 PM
castback's Avatar
castback castback is offline
Send a message via AIM to castback Send a message via MSN to castback
bore it.bigger displacement. do a vtech headswap
Old 10-07-2003, 10:28 PM
castback's Avatar
in the september turbo mag. they do a 200hp integra that is smog legal.they use cams throttle body and edelbrock intake manifold and other stuf
Old 10-08-2003, 12:46 AM
as stated before, not possible with boltons, even all of them..... nitrous, turbo, supercharger....that's the only way unless you want to open up the motor. Even a built head will not get you up to 200hp.....close, but not quite, and besides, you'd kill your drivability trying (low end would blow)
- Nathan
DTC problem: GM Serv. Dept Rip-off! Need Expert Advice, cough technicians... s_jo4 Grand Prix 7 06-06-2004 10:37 AM
confusion!! need expert advice udelblue Engineering/ Technical 3 03-08-2004 11:41 AM
Need Expert Advice 94AccordEX Accord/TSX/Accord Hybrid 10 01-20-2004 01:14 AM
Seeking Expert Advice on Modding 95 GT/vert 1ARACE Mustang Talk 7 12-14-2003 01:37 PM
Experts- advice needed D[X]P 3 Series 7 09-13-2003 09:20 AM
