Old 01-16-2004, 11:06 AM
94AccordEX 94AccordEX is offline
Need Expert Advice
I have a 94' Accord EX with 105K miles. Three days ago, replaced timing belts, water pump, engine seals, head gasket. When I went to pick up my car, I test drove it and found that the car shakes a bit while idling, but dissapears when driving. This did not happen before. The mechanic said it was normal due to the new parts and should go away. Anyways, it still hasn't gone away and is annoying the hell out of me. Should I bring it back to that mechanic and make him fix it? What could be causing the shaking?
Old 01-16-2004, 11:22 AM
accordztech accordztech is offline
Send a message via AIM to accordztech
Re: Need Expert Advice
no tell him to find the cause of it, check the motor mounts. none of the things he had done should contribute to shaking unless he also forgot to re-adjust the idle.
keep taking it back and complain.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 01-16-2004, 12:42 PM
Thanks for the advice. I am going to bring it back and complain like hell. mechanic said it just needs a tuneup to fix problem but I got suspicious he was trying to milk me for another $250. I said no, didn't need tune up. I'll tell him to find out what's causing the shaking. Thanks.
Old 01-16-2004, 01:00 PM
HONDA_99 HONDA_99 is offline
its not normal.
he might missed mark on camshaft. when crankshaft not in phase with camshaft rough idling will be present. combustion chamber must be perfectly sealed for combustion cycle. and when its not, fuel mixture ignite too late or too early (depends on camshaft position) causing engine vibration.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 01-16-2004, 10:44 PM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
timing sounds like the cause.. but.. lets see what the mechanic says
Old 01-16-2004, 10:46 PM
u tell him, it worked before u worked on it....so he cant say bullshit that it needs a tune up.
Old 01-16-2004, 11:13 PM
EclipseACCORD's Avatar
EclipseACCORD EclipseACCORD is offline
Isn't there a limited warranty on the job?
CAI sounds so good.... but not as good as Eclipse I.C.E.
Old 01-17-2004, 09:16 PM
Brought it back to mechanic, told him he had to fix it. Turned out idle was too low and timing was off a bit. Shaking and vibrations for the most part is gone but still vibrates a tiny bit. I guess I can live with that for now.
Old 01-18-2004, 03:46 AM
i knew it...hehe good job.
if anything else happends bring it back right away...
Old 01-20-2004, 01:12 AM
Thanks for all the replies. Accordztech hit it pretty close. The mechanic kept playing with the idle and got rid of most of the shaking, but its still vibrating slightly. Now the engine whistles a bit during acceleration. Prolly need a tuneup since its got 105k on it when I bought it. Might bring it elsewhere this time.
Old 01-20-2004, 01:14 AM
im always right, im a tech =)
well i check the sparks and possibly change them, the wires and the distribitor cap and rotor. those make engines run like shit or ride like new
