i have a 93 grand cherokee and im having a problem with my liftgate. when i disarm my alarm the remains in what seem to be in a lock position even using the key does not help. I wanted to know if anyone has had this problem and if tell me how to fix it.
Re: liftgate
More than likely your slider bar inside has broken or fell off. You'll have to get the door panel off and look inside. |
Re: Re: liftgate
getting the panel off isnt gonna be easy due to the fact that there are about 4 screws that you cant get to when the liftgate is closed... those screws are located around the window... what i did was grab a pry bar and just snap the panel off the screws.. yes i know not the best thing to do but my liftgate works now and there was no other solution heh... also there are 2 screws in the panels carpet area that you might not see if you dont just feel around for the holes... once you get the panel off you should just have a insulation cover to rip off and you can get to everything to fix your issue... hope this helped
Re: liftgate
I have a 94 Grand Cherokee Limited, I have a similar problem every onc ei a while, here is what I do to open the liftgate. just push in on the liftgate and pull the handle and open it. |
I would like to say thank you to every one that help me with this liftgate problem. This pass weekend after about an hour and a can of WD-40 and a few nice cute on my arm I finally got it open.
