Old 09-29-2003, 12:22 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
How do you tell the difference...
...between a first gen JDM b16 and a second gen, and also how do you know if it came out of the integra xsi or whatever car it supposedly came out of?
Empty Pockets Racing Member #1
Old 09-29-2003, 01:03 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
well its really easy to change valve covers but the 1st ge,n the vtec is small on it and the 2nd gen, the VTEC is big. if you really want detailed info about what it came out of, there are #'s below the engine code that you can look up. Also, if you are buying the full swap, the 1st gen is cable and the 2nd gen is hydroulic. If you need more info, just ask.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-29-2003, 10:47 AM
GScivic7's Avatar
cool, thanks. my friend just bought a 91 teg w/ the swap and i was trying to figure out which engine he had, looks like he's got a 1st gen
Old 09-29-2003, 05:23 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
AN easier way to tell is to check the three round seals on the head above the header. They all have numbers on them and the first seal is the year of production.
Old 09-30-2003, 08:06 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: How do you tell the difference...
White plugs = 1st gen
Grey plugs = 2nd+
Also the thermostat housing is different, other than that you need to open it up, as too many tihngs on the outside (valve covers, and intake manifolds) can be changed.
325 engine or 525 engine, how do you tell the difference? Ferngee 3 Series 2 04-17-2008 01:36 PM
How can you tell the dif between the stock kl03 engine and the klze doorknob329 Probe 3 04-19-2005 01:17 PM
How do you tell the difference between S and SI? suprachica779 Prelude 10 03-01-2004 08:42 PM
How do you tell the difference between the 165HP and 200HP 4.3L V6?? unbeatable General Discussion 6 02-21-2004 07:40 PM
How can you tell the difference between a 305 and a 350? MajorProblems Camaro Discussions 4 10-15-2003 10:26 PM
