Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-04-2005, 10:33 AM
doorknob329 doorknob329 is offline
Send a message via AIM to doorknob329
Smile How can you tell the dif between the stock kl03 engine and the klze
I am looking to buy a new motor for my car and i dont know how to tell the klze and kl03 apart. i am wanting to buy a klze and dont want to be ripped off.
Old 04-04-2005, 11:47 AM
bargersaudio bargersaudio is offline
The only difference that I could see was the KLZE was stamped KLZE right on the block. It is located on the lower rear right side of the block.
Old 04-14-2005, 01:06 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: How can you tell the dif between the stock kl03 engine and the klze
The throttle body elbow is much bigger and looks more square as the KLO3 has a bend.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-19-2005, 01:17 PM
mikentc90 mikentc90 is offline
Mr. Williams is correct, but he failed to tell you that what he means by bigger is that the neck for the throttle body is longer by at least 7 inches. The other way to tell is if the intake manifold is taken off, look at the intake ports on the heads. They should be rectangular for the KLZE and they are oval on the KL03. If the Intake manifold is on the engine look at the three individual manifold (legs). They should be rectangular, not oval.
