Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 09-27-2003, 07:58 PM
deklof deklof is offline
Angry Help removing right front axle
Well I thought it would be easy to replace the outer right CV boot! Boy was I wrong. I have everything disconnected including brakes, lower ball joint, upper strut bolts, tie rod end, etc. The hup carrier is completly free, but I cannot get the axle out of the hub nor out of the end of the transaxle. If I can get the inner CV joint free I can use my press t get the axle out of the hub, but after removing the inner boot clamp it still won't come free. Anyone have a clue how to get the darned thing apart?
Thanks
Dennis
Old 10-20-2004, 10:38 PM
G2bpr G2bpr is offline
Send a message via Yahoo to G2bpr
Re: Help removing right front axle
Thanks
Dennis
you got to remove 3 bolts that are located above the mufler pipes , its a mount atached to the axle.
Old 11-20-2004, 05:05 PM
Cbass94's Avatar
Cbass94 Cbass94 is offline
Send a message via MSN to Cbass94
Does anybody have any more information on this? My brother in-law's cv joints are bad, and need to be replaced. I will probably be doing it for him, and I was just wondering if anybody had any other suggestions/tips to make the process go more smoothly? Is there a write up on the internet anywhere of how to do it?
Any help is appreciated!
His is a 1990 MX-6 manual also.
"OK, who's the deadman that hit me with the salt shaker?!"
"Kick his a$$ Sea Bass!"
Old 11-21-2004, 12:49 PM
UsedElixir UsedElixir is offline
Thanks
Dennis
RED RED
First off, you do not need to remove all that just to get the axle out, secondly, there is something you missed, the axle does not go directly into the tranny, it first goes into another "arm" which name I'm at a loss of right now, that arm is bolted onto the block by 3 bolts, the only thing you need to do to get the axle out is disconnect the axle nut on the end, the one bolt that presses againt the balljoint and the 3 on the block than get a pry bar and pry on the inner lip of the axles "arm" that goes into the tranny, I'm sorry Im at a loss and can not remmeber the actual name of the part..here a picture
[tranny]{-rod-3bolts}{axle presses in here}heres the hub
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 09:16 PM
can someone help me with my right front axle plz? mari517 Grand Prix 2 03-01-2009 06:53 PM
Right Front Axle BIGPROFITT Montana/Montana SV6 7 08-26-2008 09:08 AM
95 Ram 1500 4X4 right front axle U-joint replacement giddy Ram Pickup | Ram SRT10 5 10-29-2005 06:22 AM
Alternator & Right Front Axle Hello11 626/Capella/Capella Wagon 0 02-24-2004 07:05 PM
