Old 09-27-2003, 03:47 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Unhappy Idle problem
Ok my car starts up fine, but it idles very high. I hit the gas and then it sounds normal but idles up and down, up and down but never smoothes out. I have tried adjusting the idle (screw) but either it idles high or up & down? What should I do. I just got my head fixed and put on, so should it be like this for awhile? Will it stop?
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 09-27-2003, 04:34 PM
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
my car does that too, but after its warmed up it stops.
Name is Adam
Old 09-27-2003, 08:14 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
3 things (4 if you've bent the idle screw).
#1 Check the vacume hoses to your manifold (unlikely).
#2 Fast Idle Valve will need replacing (located on the block).
#3 Get a new/second hand throttle body with the Throttle Position Sensor UNTOUCHED, as in having the original sealed screws in it. Do NOT buy it if it's been tampered with or reset.
Reset the ECU and drive away happy
It always seems to be these things
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 03:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 09:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 11:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 08:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 12:27 PM
