Old 09-26-2003, 07:03 PM
laurencerj laurencerj is offline
Unhappy 97 V-6 3.8 LaSabre engine hesitation at 40
Engine hesitates (slips, lugs?) at 40 mph (shift point?). The dealer says it's the trans valve body (per a service bulletin). The trans shop (twice) says no way, trans is good and lock-up converter is good. He says it's a tune-up. Tune-up shop says it may be a fuel pump but he's not sure. Anyone have a known fix? Dealer- Petre; Trans shop- TriCity; Tune-up shop- Salem Boys (all Phoenix area). No check engine light- ever.
Old 09-27-2003, 12:43 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 97 V-6 3.8 LaSabre engine hesitation at 40
Try the spark plugs, that can cause a delayed gear change.
Old 09-27-2003, 04:03 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I would say you have a trans problem. If you had a misfire the check engine light would come on setting a code P0300 in the computer. Since you don't have a SES light on and that trans is known for this problem. I have changed many PWM solenoids inside for a shudder.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 10-15-2003, 10:31 AM
RABarrett RABarrett is offline
My concern is that there is a lot of diagnosis going on with no checking of these issues. There are ways of checking these possibilities, the GM manual is full of them, I have others from my experience. The first method is to confirm the problem. There have been oodles of complaints at these speeds, all typically revolving around the TCC (Torque convertor clutch). These engines are typically bulletproof. Just because there are no codes, doesn't mean that there no problems. Since you are seeking answers, find a shop willing to ask the correct questions and go from there. I can help, but without having the vehicle to look at, diagnosis is difficult. I have done my share of electronics work in my 40 years as a tech; I am sure I can assist any shop willing to look at it for you. Ray
Old 12-30-2003, 11:32 AM
bernadette bernadette is offline
I am having the same problem with "lugging" at at 40 mph. I have 50K miles on her. I don't think that there is a blown or cracked cylinder, because the engine is quiet and it doesn't vibrate at all. Why is she hesitating on me?
3.8 engine diff than 3.8 supercharged engine wesa69 Grand Prix 13 01-23-2010 07:46 PM
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 12:43 PM
HI'S AND LOWS OF GM 2.8, 3.1, 3.4, 3.5, & 3.8 LITER ENGINES? CARNIGG General Discussion 7 12-05-2004 09:23 AM
94 3.8 LaSabre Fuel Starvation ghink LeSabre 4 02-19-2004 10:34 AM
