Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 09-26-2003, 06:48 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
"The headlight mod"
Here is my step by step instructions with pics. These are written for an 02-03 Impreza, but you can do this to just about any car, Subaru or not. I've personally done this to a Talon TSi, IS300, and a Civic. All came out great, it's a super mod considering it's almost free. You could do different variations by taping off areas you don't want painted, or designs, or painting with different colors.
These pics were taken a looong time ago, that's what my car used to look like!
Before pic:
Step 1. Remove the headlights. Open the hood. 1st to come out is the grill, it is held in place by clips. You will need a screwdriver or other fairly pointy object to reach in and push the clips while you pull and it will come out. next are the "cheeks", those little pieces in between the grill and lights. There are little black clip thing, you have to pry up the middle part of them away from the outer part, then you can pull the out and the cheeks slide out. Now the lights, There are 3 bolts on each light, IIRC they're 10mm. 2 on the front edge facing forward and 1 on the top facing up. Dont forget to unplug the wiring harnesses, there is a harness for the headlight bulb and another for the blinker.
When you get it apart it should look something like this
Now put the headlights in the oven and cook them. Really. 'Bout 250 degrees for around 5-7 minutes. This is to make the goo gooey again. If you take them out and it's still not gooey enough to pull apart, cook it longer. Don't worry about the wires on there, it's not hot enough to melt them.
Once it's gooey enough, pull the clear cover away from the main housing. There are little clips around the edge, I had a friend pull it apart while I undid the clips with a screwdriver.
It's hot, but not too bad. Gloves are a good idea, but not necessary
Then take all the separate pieces apart
Tape off anything you don't want painted. Lay some newspaper or something down you don't mind getting painted, and lay your chrome trim pieces on there. Here's what the pieces look like
Paint away! I used "high temp engine enamel" in flat black from Wal Mart
After you get a good solid color, give them plenty of time to dry. I put a hot spotlight on them to help them dry
Wipe out all the headlight housing so you hopefully won't get any condensation, then put it back together the way you took it apart. I chose to not put the orange piece from the blinker back in, the effect is clear blinkers. You probably won't be able to push it back together enough to clip the clips yet, but that's okay.
Now cook it again, same time as before. After it's cooked you should be able to push the clips together. Push it together as much as you absolutely possibly can, this will help prevent condensation. You want a perfect air tight seal. Then cook it for another mintue or 2 and push it together a little more. They sell a sealant at Autozone type stores you can use for extra seal, or I don't see any reason why silicone caulk wouldn't work. I didn't use anything, and 1.5-2 years later I still have no condensation.
Now just put the car back together. Headlights 1st. It's easiest if you slide the bottom of the light in place 1st, then wiglle it around till the bolt holes line up. Then the cheeks and grill clip in. Done!
After (after a few other things as well )
Yes, once you do this, you'll have really hot Mitsubishi employees and decent looking Hot Import Nights models rubbing all up on your car too
Old 09-26-2003, 10:17 PM
MB38's Avatar
MB38 MB38 is offline
Send a message via AIM to MB38
Only the last few images load for me... did you use a different server for the first ones?
Old 09-26-2003, 10:38 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
i cant see any images!!
Failure is only the opportunity to begin again more intelligently.
Old 09-27-2003, 12:13 AM
ssjwizard ssjwizard is offline
Send a message via AIM to ssjwizard Send a message via Yahoo to ssjwizard
cool idea. i like the way that turned out dude i may just consider doing it for the sake of another bit of customisation.
Old 09-27-2003, 12:58 AM
LjasonL's Avatar
Some Guy
They all work for me... give me a second I'll move them to my own server
Old 09-27-2003, 09:40 AM
Alldar's Avatar
Alldar Alldar is offline
i can see the images and dude that is pimp-tastic
Old 09-27-2003, 10:57 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: "The headlight mod"
Thats a great idea man. I like how it turned out.
Old 09-27-2003, 11:02 PM
SuPeRcAr_MaN's Avatar
SuPeRcAr_MaN SuPeRcAr_MaN is offline
Re: Re:
Same here.
My Webshots
headlights davidrobert2 Intrepid 1 11-20-2009 03:02 PM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 07:05 AM
01' Headlights frehleycomet Sebring | Sebring Coupe | Convertible 2 04-14-2009 09:47 PM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 07:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
