Old 09-25-2003, 08:46 PM
MikePercak MikePercak is offline
2000 ford Taurus Keyless Entry
I just bought a New Keyless entry to raplace one I had lost can anyone explain how to program this thing. It did not come with instructions. I have a 2000 Ford Taurus. Please help, and I hope I did not repeat anyones request. But I could not find another post for the same problem. Thanks for your help !!!!!!!
Old 09-25-2003, 08:53 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: 2000 ford Taurus Keyless Entry
This is a Chevrolet forum. You might want to go into the Ford forum and ask.
Old 10-01-2003, 12:05 PM
Pokey Jr Pokey Jr is offline
Cycle the key in the ignition from lock to run 8 times within 10 seconds ending in the run position. The locks should lock and unlock.
Now press any button on one transmitter and it should lock and unlock again. Do the same for the second transmitter and it should lock and unlock, then switch the ignition off and it should lock and unlock once more. Verify that the keyless entry transmitters work properly.
You must have at least two transmitters to program. (even if one works)
Up to 8 keyless transmitters can be programmed to one vehicle.
That is what Ford says. I can program two on my car, but it won't accept the third Fob. I guess it is the wrong one. I had it left over from my Marquis.
Anyway, I know this is how you program them, so good luck and have fun.
Old 04-18-2004, 10:01 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Close....
This procedure works for 1998 + Taurus models:
Cycle Ignition from OFF to RUN 8 times within 10 seconds, ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter ( up to 4 transmitters total possible ). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
I have these remotes available in my Ebay store.
Old 06-19-2004, 10:35 AM
chamilton chamilton is offline
Re:1998 ford Taurus Keyless Entry
The 1998 Taurus I have did not have a remote and I am attempting to program the remote myself. The car has automatic door locks, but is it necessary for the car to be set up to use this procedure? The car is not entering a program mode when I use the steps listed.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 05:40 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
Keypad Entry Code for 2000 Ford Taurus tleeburks Taurus | Taurus Wagon 3 04-20-2008 09:43 AM
Taurus Keyless Entry edsathome Taurus | Taurus Wagon 4 04-18-2004 09:59 PM
