Old 09-21-2003, 11:16 AM
edsathome edsathome is offline
Taurus Keyless Entry
I purchased a used 1996 Taurus some years back and would like to find out if this vehicle has keyless entry. Is there any way to tell thru the VIN or can I look someplace for a reciever. Thanks,
-Ed
Old 09-21-2003, 07:23 PM
Alex_Perry Alex_Perry is offline
the reciever should be in the back trunk towards the front near the wheelwell (I could be wrong on a 96, but thats where the unit is in my 93)
but if you dont have the keypad on the door, you dont have it.
Old 11-14-2003, 05:14 PM
peruano34 peruano34 is offline
Send a message via AIM to peruano34 Send a message via Yahoo to peruano34
Headlights
hey people, i have a problem with my headlights and interior lights diming when my car is stopped at a red light. as soon as i start driving they get brighter...anyone know what could be the problem?
Old 11-15-2003, 11:13 PM
sounds like the charging system is going south. test the battery and the alternator. the battery while the car is off should be 12 volts, and while its running it should be 14-ish volts.
Old 04-18-2004, 10:59 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Taurus Keyless Entry
These instructions will work on Taurus models, 93 - 95:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
These instructions will work on Taurus models 96 - 97:
Cycle ignition from OFF to RUN 5 times within 10 seconds, ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
1992 taurus keyless entry stanman13 Taurus | Taurus Wagon 1 11-20-2005 08:04 PM
99 taurus keyless entry/radio problems kohlio98 Taurus | Taurus Wagon 4 07-22-2005 09:15 PM
2000 ford Taurus Keyless Entry MikePercak Taurus | Taurus Wagon 4 06-19-2004 11:35 AM
