Old 09-24-2003, 07:14 AM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Tamiya Gunmetal question...
does TS-42 (Light Gun Metal) require a metal primer? or can i just use the normal primer?
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 09-24-2003, 07:43 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Re: Tamiya Gunmetal question...
Usual primer is fine
Steve a.k.a. Hiroboy
Old 09-24-2003, 11:14 AM
gasman03's Avatar
gasman03 gasman03 is offline
I recommend using primer under everything
Old 09-24-2003, 11:20 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
I used White Primer under it and it turned out fine.
Old 09-24-2003, 01:38 PM
blueboost's Avatar
blueboost blueboost is offline
and if you wanted the gunmetal color slightly darker, you can choose to use a grey primer instead. either way would work.
Old 09-24-2003, 02:22 PM
khart khart is offline
Send a message via Yahoo to khart
I use primer under most everything ... however, Tamiya paints can be sprayed on bare plastic without crazing or other trauma.
Old 09-25-2003, 01:01 PM
jdmaccordian's Avatar
jdmaccordian jdmaccordian is offline
Send a message via AIM to jdmaccordian
i've sprayed light gunmetal on bodies and many parts w/out primer and turn out fine (as long as the parts are white or gray). I actually hate primer, everything I use it on turns out bad. I avoid it altogether! G'luck
djMS
Old 09-25-2003, 01:02 PM
Diesel2NR's Avatar
in my experience, tamiya is also prone to chipping without primer. That's my experience though. They won't craze the plastic, but you'll get a better paint job.
Tamiya Gunmetal Supra!!!!!!!!!!!!!!!!! Some_Kid WIP - Street 7 06-05-2006 01:36 PM
Tamiya Gunmetal hobbes874 Car Modeling 4 09-07-2003 10:07 AM
Tamiya clear question buzzconroy Car Modeling 5 08-21-2002 06:58 AM
tamiya wrx questions datamike Car Modeling 6 02-06-2002 11:44 PM
