Old 09-23-2003, 09:58 PM
ykwak ykwak is offline
Unhappy 99 Accord DASH LIGHTS OUT
Well...finally replaced the oem head unit for 1999 Accord 4dr EX 5 spd.
BUT...everything is working (instrument / check lights...ac..vent), except for the dash lights / back lights for AC panel. Dimmer switch is not working, and at night time, I now have an excuse for speeding...
"I Swear I didnt know officer...look (points at dash with no lights...)"
All the Warning lights / Check lights work, the clock light and mileage lights come on for daylight driving, but the entire dash light setup is out.
I have looked for a "dimmer" fuse or a "dimmer" relay, but there's no such thing that I can find. I checked all the "interior light" and "instrument panel" fuses...and any other sort, even replaced them all...but still, the dash lights for nite driving will not come on.
Any Ideas?
Old 09-24-2003, 08:08 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
i replied to this in another thread so please try to keep it in one forum instead of 2 or 3+.
Thanks
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 08-22-2004, 09:23 PM
grier123 grier123 is offline
Talking Re: 99 Accord DASH LIGHTS OUT
Thanks
I have that same problem but I can not find the thread to which you are refering tooo.....Can you please help me out? Thnak you.....
[email protected]
Old 08-23-2004, 11:47 PM
Stereo Stereo is offline
Send a message via AIM to Stereo
sounds like the driver's side bcm is bad it's located in the fuse panel there you pull the plastic cover it's the box forward of the fuses it's a pain to replace but i've seen a few go bad the inside lights goes out and when you turn the parking lights on the odometer/trip meter light goes out also and before replaceing if it happened after replaceing the radio with a aftermarket check your dimmer lead as if grounded it will take out the new unit
Old 08-24-2004, 06:10 PM
Smile Re: 99 Accord DASH LIGHTS OUT
Sorry but I'm slow what is the BCM ( I know where fuse box is but not sure what is a BCM....
Thank you ...also I do have a aftermarket sony monitor.......I will make sure it is grounded...
Old 08-25-2004, 01:10 AM
the bcm is a body control module but on the accord it's the driver's side multiplexer unit in the fuse box on the driver's side it handles various functions of the car like key reminder and others , since you did install a aftermarket radio make sure if your not using the red/blk or if your using an adapter harness it's the orange / orange /white wires if their not used they should be taped up as they can short out the dimmer
Old 08-25-2004, 08:40 PM
I will try tomorrow, if I dis connect the unit do you think the panel will light up again?
thank you for the great info.....
Old 08-26-2004, 11:42 AM
it won't do any good now the output is bad , if the problem happened right after you installed the radio then that can be the cause if the dimmer lead is not covered but if it is covered and it happened latter then it's just a faulty driver's multiplexer
Old 08-28-2004, 10:04 AM
Thank you for your time and infromaton.........
Old 04-19-2005, 06:34 PM
sniper_99accord sniper_99accord is offline
Re: Re: 99 Accord DASH LIGHTS OUT
I have this same problem and it happened when I installed an after market cd player. How do I fix it so that thie lights do not go out when I turn on the headlights. Do I replace the multiplexer? Please help. thanks.
Old 07-26-2005, 10:20 PM
SQiX SQiX is offline
Send a message via AIM to SQiX
I'm having the same type of problem I believe... I installed a radio, now my dash lights wont come on when the headlights are on but they stay on if the headlights are off. I have a 91 not a 99 so Im not sure if the multiplexer solution is the same. How hard is it to replace?
Old 07-27-2005, 02:36 PM
J30Archer's Avatar
J30Archer J30Archer is offline
before you replace the BCM check the fuse for the parking lights. Parking Lights, Tail Lights (Not Brake lights) and gauge lights all run off of the same wire(Red with Black Stripe on a 1998 V6). So if your tail lights or parking lights do not come on it is more than likely the fuse. The fuse for all of this is inside the passenger side fuse box.
Old 07-28-2005, 11:31 PM
I checked the brake lights/parking lights. All work. I dont see this BCM... I read its on the passenger side but my fuses are in the floorboard of the drivers side... mines a 91, the only i posted in this topic was because it was simular problem.
dash lights out & automatic lights not working bbfalls Toronado 4 10-19-2010 05:51 AM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 07:35 AM
1997 Plymouth Voyager Parking / Running Lights - Dash Illumination Out levelbest Caravan | Voyager 3 09-25-2009 12:28 AM
93 accord 2.0i es dash lights out gazwellycbr Accord/TSX/Accord Hybrid 0 08-27-2004 01:23 PM
99 Accord Dash Lights OUT! ykwak Car Audio 3 10-19-2003 02:00 AM
