Old 09-23-2003, 11:02 AM
ykwak ykwak is offline
Angry 99 Accord Dash Lights OUT!
Well...finally replaced the oem head unit for 1999 Accord 4dr EX 5 spd.
BUT...everything is working, except for the dash lights / back lights for AC. Dimmer switch is not working, and at night time, I now have an excuse for speeding...
"I Swear I didnt know officer...look (points at dash with no lights...)"
All the Warning lights / Check lights work, the clock light and mileage lights come on for daylight driving, but the entire dash light setup is out.
I have looked for a "dimmer" fuse or a "dimmer" relay, but there's no such thing that I can find. I checked all the "interior light" and "instrument panel" fuses...and any other sort, even replaced them all...but still, the dash lights for nite driving will not come on.
Any Ideas? Or take it to honda and get a new hole torn open...?
Old 09-24-2003, 08:31 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
you probably blew a fuse when you installed the new deck. Im sure its just a wire that touched another one or metal. Not sure what fuse it is, but when you find it, replace it. If it blows again then you have wires touching behind the deck somewhere.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-29-2003, 11:02 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
all I can say is either, you disconnected a ground point somewhere behind the dash, or accidentally cut a ground wire, or a fuse is gone. start checking your fuses, and it might be a good idea to get those "light up" fuses that light up when they burn out. I bought a few for my amp, so next time they blow I can just look at the bottom of my amp and know which ones have to be replaced.. instead of having to pull out every single fuse in your car, but for the dash I would geuss those fuses would be in the fusebox on the inside of the drivers door. As is in my 99 accord.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 10-19-2003, 03:00 AM
glassman2k2 glassman2k2 is offline
i know on some of those body style accords, if you use the illumination wire to light up a aftermarket deck it can mess up the lighting on the part with your mileage, it's some computer thing, about 400 dollars to fix, doesn't sound like your problem though, did you check both fuse panels inside on each side of dash??
dash lights out & automatic lights not working bbfalls Toronado 4 10-19-2010 06:51 AM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 08:35 AM
1997 Plymouth Voyager Parking / Running Lights - Dash Illumination Out levelbest Caravan | Voyager 3 09-25-2009 01:28 AM
99 Accord DASH LIGHTS OUT ykwak Accord/TSX/Accord Hybrid 12 07-29-2005 12:31 AM
93 accord 2.0i es dash lights out gazwellycbr Accord/TSX/Accord Hybrid 0 08-27-2004 02:23 PM
